Old 09-10-2014, 01:37 PM
knobbyboy knobbyboy is offline
Default sprockets
About time to replace them. Currently on 2011 250EC is 13/52. Bike came with a new front 12 so better believe i plan to use it. thinking about 49 or 50 rear with the 12. tight woods SE riding. thoughts and suggestions?
Old 09-10-2014, 04:16 PM
liv2day's Avatar
liv2day liv2day is offline
I'm running 12/50 on my 200 and it's perfect for the terrain we ride - which sounds similar to what you're in. I give a little up when we head out to open ground (similar to desert riding), but it's not enough to make me want to change anything up.
Old 09-11-2014, 08:17 PM
gasser's Avatar
gasser gasser is offline
I run 12/48 in the Tennessee hills on my 250 and it's perfect for me. 13/52 will give the same ratio. Some say the chain wears faster with a 12 cs sprocket and they are probably right but the difference is so small when you run steel rear sprockets that it doesn't change how often I replace my sprockets and chain. 12/48 does wear the chain slider noticeably faster while 13/52 will eat up the rear shock mud guard if you run trials tires or tall knobbies. 12/48 sprockets will extend your bikes wheelbase roughly 3/4 inch when compared to 13/52 sprockets running the same length chain. I like the slightly longer wheelbase because it lets me sit a little farther back on the seat.
Sprockets....where to go? Synergy-Seals General Discussions & Announcements 12 02-11-2012 01:10 PM
Chain and Sprockets Rick Enduro Chassis & Body 5 01-12-2010 11:35 AM
Sprockets Motarded1 Enduro Chassis & Body 17 05-25-2008 11:52 PM
