Old 11-04-2019, 07:58 AM
flatout111 flatout111 is offline
Default Truly converting a 17 EC250 to a EC300
Hey guys, so I am contemplating getting a 2017 EC250. When I planned on getting a pre-owned second bike I said my 2 per-requisites were e start and it be a 300. Check on the e start. So I worked out a great deal for this bike but it is a 250 which, I know, are great, but I do prefer the more lugging capibility of the 300. I also think it is better for the extremely technical.
So my question. To truly convert it to being the exact same as a EC300 what has to be done? I want it to be just like the 300 in all aspects, with the exception of paperwork, of course. I need to factor this conversion, if can be done, in on the final costs to make my decision.
Any help would be appreciated. Thanks.
Old 11-04-2019, 08:54 AM
To my knowledge, you will need the 300 cylinder, piston, and head.
Old 11-04-2019, 09:51 AM
risk74 risk74 is offline
Yup, just the cylinder, head and piston. I've turned several 250s into 300s. If you're in the market, I have a replated cylinder, piston and S3 head for sale with low hours for sale. PM me for details and pictures.
Old 11-04-2019, 10:21 PM
As above and obviously jetting, but do a check on the cdi as well. I think they are the same on gassers though.
Old 11-20-2019, 01:56 PM
I know the CDI is the same for the 18+ gassers. The dealer let me use a 300 CDI while the CDI from my 250 was sent off to be re-flashed.
Old 12-02-2019, 10:11 AM
Ended up getting a like new 300 cylinder from Jeff at Hall's Cycles plus a new piston and gaskets. This 300 cylinder was from a guy who wanted to do the opposite. He wanted to go from a 300 to a 250 so this will be perfect and about same year, too.
My mechanic wanted to know if the manual has torque values or assembly tolerances but I don't have a manual.
Can anyone assist with this. Jeff said it should bolt right on with no issues but I think my mechanic just wants to be sure.
Thanks for any assistance.
Old 12-02-2019, 11:45 AM
Torque specs are the same in the '18 manual.
https://www.dropbox.com/s/i93vw77r9k...anual.pdf?dl=0
Old 10-16-2020, 04:00 AM
H0msey H0msey is offline
Have any of you guys done a 125 to 200 conversation? What all would I need to do this? Its an 08 125ec what years parts can use?
Old 10-16-2020, 05:13 AM
Anders Anders is offline
The 125 and 200 motors are quite different. The 200 is a scaled down 250/300 with a short stroke crank and smaller bore. None of these parts will fit the 125 cases, I believe.
People have converted their 125s into 144 with great success, but I presume that's how big it gets.
Converting a EC200 to a EC300 Ply318ci Enduro Engine - 2 stroke 19 12-12-2011 08:28 AM
98 ec250 converting to WP forks / caliper ?? 98ec250 Enduro Chassis & Body 2 11-18-2010 12:19 PM
Converting 2009 EC300 to Motard cheekeon Enduro Chassis & Body 0 04-12-2009 03:04 AM
