Old 08-27-2020, 02:04 PM
Gasser Nate's Avatar
Originally Posted by Doc Brown View Post
Adding shims or even using a longer rod (I tried three different lenght on my former bike) will not change anything. The shim or rod will just push the slave piston back in its housing. It won't add lift.
I talked to a German dealer and he said he has brake fluid resistant o-rings for the slave. So I could change the Magura for a 10 or 10.5 mm Brembo clutch master. I am hesitating because I fear that the clutch pull will be even harder.
This is why is asked, you mentioned brake fluid resistant o rings...
Old 08-27-2020, 03:42 PM
Yes, but in context with a Brembo master. Brembo master cylinders are available in various sizes but only for use with DOT brake fluid. So some guys replace the OEM o-rings with brake fluid resistant o-rings and use a Brembo master instead of the Magura.
Clutch issues when warm ian1987 Enduro Engine - 2 stroke 3 05-17-2021 11:09 AM
Clutch issues EC250 Enduro Engine - 2 stroke 6 06-20-2016 08:26 AM
Clutch issues Trigga Enduro Engine - 2 stroke 3 09-08-2014 02:23 PM
2012 Ec250 Clutch issues... Novascotiarider Enduro Engine - 2 stroke 9 05-07-2013 12:50 PM
Hydraulic clutch bleed "read this" moto9 Enduro Chassis & Body 5 10-11-2011 10:48 PM
