#11
Warm the cyl area around the drum with a propane torch, use a longer M5 bolt to grab all the threads, it should pull out. The MC250 has the same PV parts.
#12
For the official record. After adding even more pre-load to the pv, the flutter is gone, but I now get a discernible clack when I chop the throttle. Like the pv is snapping shut. Raced the bike twice last weekend and it ran perfectly fine...I'll learn to live with the noise because it's definitely not affecting the fun factor.
After I rode it like that, I tightened the drive chain to spec and rode it again - no difference..just had to rule that out.
Al Bunch 2008 EC300 2008 YZ250F 1999 GasGas TXT270 AMA (www.ama-cycle.org) TRH (www.trh-cycle.org) MSRA (www.msra-cycle.org) I may not be able to tell you who you SHOULD buy from, but I can definitely tell you who you SHOULD NOT buy from. |
Engine noise | roostafish | General Discussions & Announcements | 11 | 11-24-2009 12:01 PM |
Top end noise ? | Link | Enduro Engine - 2 stroke | 7 | 01-17-2008 03:33 PM |
clutch noise? | LAWMAN | Enduro Engine - 2 stroke | 9 | 01-16-2008 08:15 AM |
Bad Noise | roostafish | General Discussions & Announcements | 17 | 01-10-2008 08:30 AM |
Exhaust noise | captainslow | Enduro Engine 4 stroke (including EFI & Exhaust) | 1 | 12-10-2007 07:26 PM |
