Old 02-05-2020, 10:01 AM
ian1987 ian1987 is offline
Default Rear wheel bearings
I have been having issues with rear wheel bearing wear on my 300 ec. I noticed recently that the washer which goes between the 2 bearings on the sprocket side is actually missing.
I have ordered the washer but have read on a few forums that there is a right and wrong way to install the washer. Has anyone a photo of the correct setup or can advise?
Cheers
Old 02-05-2020, 10:11 AM
http://www.gasgasrider.org/forum/sho...bearing+spacer
Old 02-05-2020, 10:15 AM
thanks for the quick reply
I had read that post but the photos are blurry so cant make them out
Old 02-05-2020, 12:17 PM
You're welcome.
Basically, the stepped surface faces out.
Old 06-04-2021, 12:58 PM
Hooligan Hooligan is offline
There is a stepped surface on the washer that fits into the larger outer bearing. Its kind of a one way fit thing.
Rear wheel bearings Wes32 Trials Chassis & Body 1 10-23-2016 10:49 PM
Rear wheel bearings on 03 kendunn Enduro Chassis & Body 8 01-06-2011 05:43 PM
Rear Wheel Bearings cladoo Enduro Chassis & Body 2 11-18-2008 10:14 AM
05 ec 300 rear wheel bearings burgo General Discussions & Announcements 1 06-08-2008 03:32 AM
rear wheel bearings smithys ec250 United Kingdom 3 04-23-2008 04:01 PM
