Sachs fork springs crossover
I want to put in heavier fork springs in my 09 ec300. Sachs 48. What is the crossover spring size for sachs. some say, 05 yz450f, and indeed those springs match the dimensions very close.
race tech shows: FRSP 444650 RT FRK SPR 44.0x460mm .50kg Length=460mm outside diameter=44.0mm FRSP 444750 RT FRK SPR 43.6x472mm .50kg Length=472mm outside diameter=43.6mm (this is the yz450f spring) The stock Sachs Spring is 43.3 O.D. x 460 mm long. |
I use the 4447 with my 2011 forks, the stock preload was essentially zero, 12 mm is a bit more than the magic 10 mm people quote for shocks, but forks are a longer spring. It feels quite normal and fits perfect, between years there seems to be differences in the fork caps.
I have a set of 0.44s for sale that have about 6 hours on them.
Going to .50 on it, but thanks.
We usually keep the proper fork springs in stock at the shop so we don't have to worry about mixing and matching, but once I get into the shop this morning I'll see what info I can get.
RaceTech isn't the only spring source... |
Just a follow up- I figure you've already got what you needed- were you looking to see what was available for your bike or looking for something you could take out of something else you had laying around and fit to your bike?
What I'm getting at is that both of the companies I get springs from (Cannon and Eibach) have proper solutions for the fork- springs are about $110 for the fork- Hope that helps... |
Are you recommending the 43.5 x 461 in the Eibach book?
2018 EC 300 |
Sachs Fork - For the record | Zeal | Enduro Suspension | 2 | 05-25-2010 09:20 PM |
Sachs fork springs? | Zeal | Enduro Suspension | 2 | 03-19-2010 10:05 PM |
sachs fork | moto9 | General Discussions & Announcements | 0 | 09-28-2009 07:51 PM |
