Old 12-04-2017, 12:38 PM
Marcão Marcão is offline
Hi,
At the end, the solution was a mix of some sugestions... I "glued" the nut to the frame using some loctite, then added a aluminium washer with larger ID and a "pressure" washer (black) to the alen bolt. It seems to be relatively firm.
The problem now is the bottom of silentblock rubbing the tank (in fact a problem since brand new...). But this will be a next fix...
Thank you all !
'05 GAS GAS EC 250
'15 KTM EXC 350 F
'16 BMW R 1200 GS
'83 Honda CB 400
loose front wheel gump147 Enduro Chassis & Body 3 05-05-2015 12:40 PM
Ferderer at the Loose Moose! Rod Overstreet Off Road Racer's Corner 7 06-29-2014 11:23 PM
Loose Airscrew biggstr6 Enduro Intake/Carburetion - 2 stroke 6 07-29-2010 09:07 AM
loose bottom marzocchi cap noobi Enduro Suspension 2 06-06-2010 07:48 PM
Loose yellow wire in airbox stevethebrit Enduro Electrical & Wiring 2 09-30-2009 04:40 PM
