Ohlins shock shims
Ohlins rear shock
Kicks me in the ass, harsh and non compliant i have the following compression shims 23 x .2 24 x .2 25 x .2 26 x .25 28 x .25 30 x .25 32 x .25 34 x .25 36 x .25 38 x .25 40 x .2 22 x .1 22 x .1 40 x .25 40 x .25 40 x .25 40 x .2 40 x .2 40 x .2 any sugestions |
What year shock/chassis? Has it been revalved? it appears so on first glance.
Quite a firm stack with the .25's and the large clamp. Also a very big crossover with the 2x.1mm 22OD shims. What spring rate, what sag figures, and what's the rebound stack? |
pretty sure its stock spring, dont have it to hand to look at but ill check later
its 2006 model dont know much about the history of it, could have been revalved.Yes its deffinatley firm in the top to mid |
rebound is
36 x .2 36 x .15 36 x .2 36 x .1 26 x .1 34 x .3 32 x .3 30 x .3 28 x .3 26 x .3 25 x .3 24 x .3 23 x .3 seems quite substantial aswell |
I don't mind the look of the rebound. Where are you running the clicker though? With a stack that heavy you'd want to be 18-22 clicks open, which will allow some free bleed in the comp circuit. If you've got the rebound closed down anywhere past 16 it really starts to make the comp harsh.
I have the OEM stacks here, can post them if you like. |
I tried heaps of setting but not much good
Oem stacks would be great if you have them handy Rinning a 54 spring |
Comp
40x.2 (10) 34x.1 30x.15 40x.2 (3) 38x.25 36x.25 34x.25 32x.2 30x.2 28x.2 26x.2 22x.3 Rebound 36x.2 (5) 28x.15 36x.25 34x.25 32x.25 30x.3 28x.3 26x.3 25x.3 24x.3 23x.3 22x.3 |
2012 Ohlins lower shock bushing and Problem with shock. | CDBiker220 | Enduro Suspension | 1 | 08-04-2014 09:35 PM |
WTB Ohlins Shock | GasGasDreamer | "Wanted to Buy" & "Want To Trade" | 4 | 03-05-2014 05:04 AM |
ohlins shock | redrider7202 | General Discussions & Announcements | 4 | 06-10-2010 11:00 AM |
Ohlins shock diy? | jostby | Enduro Suspension | 2 | 03-14-2009 01:12 PM |
