Old 03-22-2016, 09:27 PM
NM_GG_Rider NM_GG_Rider is offline
Default Torque specs :(
Ok, I have to walk away from the bike now...! According to manual I downloaded, it said 25 nm for bolts and nuts of 8 m size, but I just twisted the top of one of these bolts that secures the front axle right off.
So did I read the manual wrong? Help 😒 What should the torque for these bolts be?.
Thanks, Rob
Old 03-22-2016, 09:37 PM
8mm is the diameter of the bolt, not the socket size.
You put 18ftlbs of torque on the bolt.
Old 03-22-2016, 10:28 PM
Default 18 ft pounds...
Woah! 18 ft pounds is still over 200 inch pounds (not much less than I had it set for)
Found another post where somebody's 250 manual lists them as 4 nm or about 35 inch pounds. I think I'm gonna go with that and then do a key word search before I tighten things now.
Thanks,
Rob
Old 03-23-2016, 12:17 AM
This might give you a little more to work with. Don't trust anything in the manual. Much has been lost in translation. Also take note of the thread size compared to the table. Parts change from time to time, so you need to factor in what you have in your hand compared to what's written down.
End of the day, I find a ktm 250/300 manual more useful in terms of what to use Loctite on, torque for particular sized threads, etc.. but also, don't rely on the wrench any more than I do feel. Triple clamps are the exception - you don't want these too tight.
Old 07-23-2019, 07:18 AM
Davehuge's Avatar
Davehuge Davehuge is offline
On that torque table it says Front Axle Clamps are M8 and torque to 15Nm... But mine are M6 bolts.
It's a 2004 EC300 with Marozochi's, what should torque be?
All the best, Dave.
Old 07-23-2019, 07:41 AM
SS109 SS109 is offline
All the best, Dave.
I use 8 nm or 71 in-lbs on the pinch bolts.
Old 07-23-2019, 08:56 AM
Davehuge's Avatar
Sounds good, thanks.
Old 06-30-2021, 02:58 PM
5valve 5valve is offline
2018 model 300
Is torque for M6 bolts for engine cases known? Old manual for '06 model states 10Nm.
New user manual has only one case bolt specified at 12Nm, so i presume this is for all of them.
Probably giving them only 10Nm also wouldnt hurt, as it is subtle difference.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 06-30-2021, 03:53 PM
Originally Posted by 5valve View Post
2018 model 300
Yes, that would be for all of them. I personally would torque them to what the current manual states unless someone can provide a reason not to.
Old 07-01-2021, 05:35 AM
10nm is plenty and pretty standard for 6mm bolts. You won?t have any issues at that spec
'06 EC 300 bar specs brider Enduro Chassis & Body 1 07-30-2014 01:34 AM
Fork Clamp Pinch Bolts - Torque Specs JP4 Enduro Suspension 1 03-09-2012 02:03 PM
torque specs kstreet Enduro Engine - 2 stroke 1 01-28-2011 07:05 PM
05 De 300 Specs VORMAN Enduro Electrical & Wiring 9 11-14-2010 06:36 PM
Torque Specs steve Enduro Engine - 2 stroke 8 02-26-2008 09:30 PM
