Old 09-20-2018, 01:32 AM
Mikeyx Mikeyx is offline
Default Crossover for BE870002510 silencer?
I need a new can for my EC300 Racing, m.y. 2009.
Is there an alternative to the OEM silencer BE870002510 ?
Old 09-20-2018, 03:34 AM
Why? Has the std inner fallen apart? You can rebuild them with some perforated tube and someone with a welder.
Old 09-20-2018, 04:22 AM
Rivets won't last long and hence the rivet holes have stripped through the shell.
Old 09-20-2018, 11:01 AM
Neil E. Neil E. is offline
Drill it out and use the next larger size of rivets?
Old 09-20-2018, 01:55 PM
You can get some larger but larger head rivets that hold better, you know the ones? They are like 12mm heads.
Old 09-24-2018, 04:23 PM
Davehuge's Avatar
Davehuge Davehuge is offline
Hi Mikeyx
If you decide to replace your silencer, I can strongly recommend the DEP silencer, good quality and great price...
See this post...
http://www.gasgasrider.org/forum/showthread.php?t=23568
Old 09-26-2018, 02:56 AM
Thanks Dave - this is just what I've been looking for.
The flange of the incoming pipe, which is riveted to the shell, has no longer holes but U-shaped openings instead...
Old 10-13-2018, 10:54 AM
Found the root cause to my problems. Retainers BIC050526004 and BE25626004 were toast.
I found an OEM silencer for an affordable price from gasgas-outlet.de. They deliver to Europe only.
Silencer crossover rzide Enduro Engine - 2 stroke 3 03-02-2014 01:20 PM
12' silencer john r b Enduro Engine - 2 stroke 15 04-22-2013 02:41 PM
07 silencer cbutler Enduro Engine - 2 stroke 1 03-25-2013 08:25 PM
Does a '07+ silencer fit a '05 ec 300? steliost Enduro Engine - 2 stroke 11 06-08-2012 09:41 AM
