Old 04-08-2022, 06:33 AM
Yep one of the few with a 12v powered cdi. You might be lucky with just a Reg/rec. Is there a fuse on that model?
Old 04-08-2022, 05:28 PM
Cox76y Cox76y is offline
Not that I can see. Two fuses on the starter relay but nothing anywhere else that I can see.
Old 04-09-2022, 07:54 AM
Yep that is the main fuse for the harness and a spare. Just make sure that hasn?t blown. It usually does when people hook up batteries backwards.
Old 05-02-2022, 07:08 AM
I must have been lucky, I got a new regulator 2nd hand off a ttr 250. It plugged straight in with no changes to the harness. Bike works fine so thanks everyone for your input.
regards
JC
Old 10-04-2022, 06:39 AM
OK, turns out I'm not as lucky as I first thought.. Bike runs as per normal until I get to high rpm. It signs off EARLY. It's almost as though it's been put into the rain setting on the mapping switch, however it doesn't have one. I've replaced the ignition coil and the regulator. Anybody know of it is likely the stator or the Cdi? I'm not sure how to test either. Happy to send the cdi to a shop if they can diagnose it somehow..
Any ideas?
Thanks. JC
Old 10-09-2022, 06:35 AM
OK, no answer with the last post so I'll ask another question before I outlay the cash for a new CDI.. Is a faulty stator likely to effect the very top of the RPM and not effect the bike in any other part of the Rev range?
Thanks
JC
Old 10-09-2022, 02:54 PM
SS109 SS109 is online now
Test the output. If it's within spec then that's not your problem. Check plug wire, clean all ground connections, and make sure your ignition coil is good and grounded properly.
Old 10-12-2022, 03:54 AM
Thanks for your info ss109. Any idea what the output should be?
Old 10-13-2022, 11:33 AM
Neil E. Neil E. is offline
From the old service manual.
Old 10-14-2022, 03:09 PM
Thanks very much Neil E.
Oops, overheated ec300, what's the damage? solstice Enduro Engine - 2 stroke 15 01-01-2014 04:42 PM
oops .... skid jackson Enduro Chassis & Body 2 11-11-2011 12:50 PM
I stuffed my fork JRDoz Enduro Suspension 5 07-14-2009 02:18 AM
Oops !!! I didnt mark the grease ring on the clutch basket FFRDave Enduro Engine - 2 stroke 2 03-14-2009 02:34 AM
