Old 10-04-2022, 09:25 AM
Topjimmyk Topjimmyk is offline
Default 2001 300 ec Rear Axle Nut
Cheers!
01 gas gas 300 ec. My rear axle nut came loose and fell off somewhere on the trail my last ride. Luckily no damage happened.
I am having a hard time sourcing a new one. Anyone know any crossover part numbers or the nut size?
Thank you
Old 10-05-2022, 01:24 PM
Anders Anders is offline
didn't really check, but my guess would be M20x1.5.
What diameter is your axle?
If you cannot find out, I can measure over the weekend
I only have newer axles to measure, but I think they are equal
Old 10-07-2022, 06:43 AM
ditezz ditezz is offline
Originally Posted by Topjimmyk View Post
Cheers!
Thank you
Is your axle mounted the correct way? The nut should be on the disc side .If the axle is mounted the wrong way ,the nut can be loosened when struck by a rock or other trail object
Old 10-07-2022, 07:27 AM
[QUOTE=ditezz;200590]Ahhh....It is a self locking nut .That would explain it being on the sprocket side ,I would still put it on the disc side ...anyway Part # BE25618023 Self Locking nut r640700
My rear axle nut good Gez Enduro Chassis & Body 12 01-25-2020 01:20 PM
Rear Axle Preszo Enduro Chassis & Body 2 01-27-2014 11:10 AM
Rear Wheel Axle singletracker Enduro Chassis & Body 38 07-24-2013 09:08 PM
rear axle Q nokturnal Enduro Chassis & Body 4 06-13-2012 10:52 PM
rear axle nut skid jackson Enduro Chassis & Body 2 06-17-2007 06:52 PM
