Old 02-20-2011, 06:29 PM
rgranger's Avatar
rgranger rgranger is offline
Default Is there an easy way to remove the rear shock?
or do I have to remove the complete rear subframe?
2011 EC300. it almost looks like it has to come out the right side after removing the airbox?
thanks
Rob
Old 02-20-2011, 06:51 PM
Remove pipe.
Place bike on stand
Remove one dog bone link bolt.Let link hang down.
Remove both shock bolts.
Raise swing arm.
Lower shock through the left side of swing arm.
Pull shock through right side of bike.
How come you're pulling the shock off?
Old 02-20-2011, 07:28 PM
roostafish's Avatar
That's nice. If that works it will literally save an hour or more.
Mike Sheetz
OMRA #21AA
'15 KTM 300 XC-W
Gran Prix Cycle
LTR Suspension
RB-Designs
Old 02-20-2011, 07:55 PM
rgranger's Avatar
Originally Posted by gasgasman View Post
Remove pipe.
Place bike on stand
Raise swing arm.
Well, I found a manual on line for a 2003, had to pull the sides, air-box and drop the bone. this doesn't look like enough room to go out the right, may try that next time.
1) they have nothing on KTM on the side panels...plastic screws, really? the head came right off one without the screw coming out.
2) plastic adjuster ring for spring, really, steel or aluminum was too heavy? I could barely get the tool to bite on the slots to remove it. Is there a metallic replacement?
3) factory spring seems to have a smaller OD than the replacement Les T installed. He added some type of inserts into the end so that there is a flat surface for the spring to ride on both ends, did the factory setup? am I missing some bits.
G, why, I wanted to try the stock 5.2 spring. I just seem to ride better with a soft setup on the back. On the KTM with the 8.0 rear, Greg and Phillip just thrashed me, put on a 7.6 and next weekend I was keeping up. I know the numbers don't work out, but I think the results say otherwise. I surely didn't get better in one week
Old 02-20-2011, 07:59 PM
It works. Being a pit bitch for Team Gas Gas has it's benefits.
The trick is to raise the swing arm up high enough for the shock to drop through.
Old 02-20-2011, 08:28 PM
rgranger's Avatar
well, it does fit back though the right side... still don't like the plastic adjuster ring! Can you find out if team GG has a metal one?
I have the shock back on, going to try and adjust sag while all the bits are off so that I can adjust it without screwing up the plastic ring.
Did you ride today? I need to get a picture of my arms from clearing yesterday, I must be allergic to something out there.
May I call you later or tomorrow?
Old 02-20-2011, 08:53 PM
A Plastic preload ring on a new Ohlins, really? WTF is that about?
Old 02-20-2011, 08:58 PM
Boomhauer's Avatar
Boomhauer Boomhauer is offline
I am giving up on you Rob. I told you to call me and I would come over and show you how to do it. Older bikes were different.
Bikeless for Now
Thanks to Smith's Powersports 724-899-3375
www.smithspowersports.com
Old 02-22-2011, 07:23 AM
onegreyghost onegreyghost is offline
Default gasgasman removing the shock
I am getting ready to do the same thing. Do u remove the rear wheel while its on the stand
2011 Nambotin
2010 300 Six Days
2008 Raga
2008 250 xc KTM
2007 200 xc KTM
To many KTM's to list
1983 175 IT Yamaha
1995 200 KDX Kawasaki
Old 02-22-2011, 08:19 AM
eff's Avatar
eff eff is offline
I just read that KTM went to plastic too.
2004 GasGas DE250
Rear shock bushing 2 strokes 4 life Enduro Suspension 1 01-30-2011 08:31 PM
Adjusting Rear Shock stuckinatree Enduro Engine - 2 stroke 4 11-11-2010 03:08 PM
Rear Shock Spring--Where Am I? Where Do I Go? smstewart Enduro Suspension 0 04-19-2010 05:35 PM
Removing Rear Shock gasIdaho Enduro Suspension 12 02-04-2009 10:45 AM
rear shock sag under bikes own weight rupecopp Enduro Suspension 7 12-18-2007 08:06 PM
