Old 02-22-2011, 02:44 PM
Keg Keg is offline
I just undid mine. I undid the subframe bolts, took off the exh, removed the dog bones and undid the carb boot. Tipped the subframe in the air and jiggled it out.
It is better to spend another 10 mins undoing more stuff than an hour trying to squeeze it out through a small gap.
EC300 2019 (11 Gassers owned, many more to go)
Old 02-22-2011, 10:06 PM
rgranger's Avatar
rgranger rgranger is offline
I can see where Girard's and Robbie's would work. Got to be easier than what I did. Sorry Robbie, I feel badly about always pestering you to help me.
I wound up putting a spacer on the top to bolts for the starter, it was dragging a bit and I read to loosen the bolts and see if it rests against the mounting surface, if not shim it. Need to get it warmed up to see if it will still howl or not
Old 02-25-2011, 07:29 AM
onegreyghost onegreyghost is offline
Default shock removal
I just took mine off and replaced it with an Ohlins TTX. I did it the way gasgasman explained it and the removal went perfect and saved a ton of time. Thanx gasgasman
2011 Nambotin
2010 300 Six Days
2008 Raga
2008 250 xc KTM
2007 200 xc KTM
To many KTM's to list
1983 175 IT Yamaha
1995 200 KDX Kawasaki
Old 02-25-2011, 09:06 AM
mrkartoom's Avatar
mrkartoom mrkartoom is offline
A Plastic preload ring on a new Ohlins, really? WTF is that about?
I was wondering myself, but read this in Chilly's test/review of the 2001 XC300. Apparently he likes it:
"One nice feature is the new nylon adjuster ring for the spring preload. This allows you to loosen the locking bolt and then spin the adjuster ring. As these are two separate parts, once the adjustment is made, simply move the locking ring back in position and tighten. It does not require a full turn."
2011 Gas Gas EC300 38mm, 2008 Husky TE610, 2003 Beta Rev3 250
Old 02-25-2011, 09:54 AM
rgranger's Avatar
How about a report on the TTX?
Old 02-25-2011, 09:56 AM
rgranger's Avatar
I found a replacement for the silly plastic rivets with screws that hold the side panels on. I have a picture on picasa, you may have to copy and paste?
Rob
https://picasaweb.google.com/1062170...DcseWwpuSX0QE#
Old 08-22-2017, 04:45 AM
Mikeyx Mikeyx is offline
Would the instructions given by "gasgasman" also work w/ EC300 2009?
Or would this https://www.youtube.com/watch?v=0bcU_bWw5uU be an easier way?
Old 08-26-2017, 11:17 AM
I tried the way "gasgasman" had suggested but it did not seem to work for my 2009 EC300. However, the method shown in the video was an easy and quick way to remove the shock.
So what needs to be done is:
- remove seat and exhaust end pipe
- remove the rubber band holding the gas tank (remove the phillips screws of side fairings to gain access), and lift the tank towards the front
- remove plastic frame covers
- remove top and bottom subframe bolts
- loosen the clamp which secures air box to the carb
- when the shock bolts have been removed, swing the subframe to the left and remove the shock towards the right
Old 09-05-2017, 04:59 AM
Cox76y Cox76y is offline
just tried this and unfortunately there is not enough room to get the shock out the right side of the bike without moving the subframe. I have the plastic subframe though and the it is wider around where you pull the shock through. Anyone that has the plastic subframe had success?
Josh
Rear shock bushing 2 strokes 4 life Enduro Suspension 1 01-30-2011 08:31 PM
Adjusting Rear Shock stuckinatree Enduro Engine - 2 stroke 4 11-11-2010 03:08 PM
Rear Shock Spring--Where Am I? Where Do I Go? smstewart Enduro Suspension 0 04-19-2010 05:35 PM
Removing Rear Shock gasIdaho Enduro Suspension 12 02-04-2009 10:45 AM
rear shock sag under bikes own weight rupecopp Enduro Suspension 7 12-18-2007 08:06 PM
