Old 07-14-2014, 01:44 PM
MYBOARDSNOTFLAT MYBOARDSNOTFLAT is offline
Default Ec300 r 2012 kickstart hitting front pipe
HI
This might be a daft question but my kickstart has started hitting front pipe when pushing it back over into place and is starting to scratch/wear top of front pipe , Nothing seems bent so wondering what is likely cause of this?
Thanks for any help.
Old 07-14-2014, 03:19 PM
Banned
Originally Posted by MYBOARDSNOTFLAT View Post
HI
Need to pull the clutch side case cover off and inspect the kick lever gears. It shouldn't swing forward.
Old 07-14-2014, 09:05 PM
MattR's Avatar
MattR MattR is offline
You could pull the kick lever and rotate it back one spline.
Matt
Current: 2009 Yamaha FZ1
Old 07-14-2014, 09:15 PM
This.
Otherwise if the issue is that its rotating in towards the bike too much check the lower knuckle and see if its been rheemed out a bit with use.
Old 07-20-2014, 05:19 PM
Thanks
Think the front pipe has takin a good hit from below and pushed upward as rad was pushed up with pipe touching it and that's why kick start been hitting it .
2012 xc 250 kickstart and 12 xc 300 e start CycleBuy New Bikes 0 01-10-2013 04:43 PM
ec300 kickstart retaining bolt krazy Enduro Engine - 2 stroke 13 09-29-2011 11:27 AM
Front tyre hitting to pipe!!! gassi Enduro Engine - 2 stroke 8 11-03-2009 06:04 AM
Shock hitting the pipe 09 EC 300 moto9 Enduro Suspension 6 07-22-2009 09:47 PM
