Old 06-01-2014, 09:35 PM
'11EC300 '11EC300 is offline
Default S3 cylinder/power valve help?
Trying to put the power valve assembly into a new S3 cylinder...I cannot seem to get it right!
After many, many, many attempts I keep ending up with the index for the triangle piece on the wrong side of where it needs to be.
The assembly will only rotate a small amount.
Remembering taking it out, the whole assembly being able to spin 360 degrees, so I put everything into the old cylinder and everything seems fine on the first try.
Is it possible something is not right with this cylinder or am I totally overlooking something simple?
2011 EC300
2013 TXT300 Factory Replica
2014 Polaris Assault
2004 Snowhawk 600H.O.
Old 06-01-2014, 10:47 PM
After taking a few minutes off and returning to it, I have realized that the flapper can not fully recess in the open position. S3 didn't machine enough material out!
If i were to take a Dremel and try to get a little clearance do I risk damaging the cylinder coating?
Really don't think I should have to but at this point seems like the only thing to do!
2011 EC300
Old 06-02-2014, 02:19 AM
twowheels's Avatar
Send it back - the stop points are critical.
Steven Beane #275
afterhourscycle.com
Old 06-02-2014, 09:02 AM
Correct me if I am wrong, but the stop points would be controlled by the bolt head stopping the movement at fully open and closed?
The material needed to be removed would be a very small amount on the uncoated side of the cylinder.
Returning the cylinder would be costly ($150-$200) with two way international shipping!
2011 EC300
Old 06-02-2014, 09:29 AM
john r b's Avatar
john r b john r b is offline
Shoot S-3 an e-mail. I did a few months back,very responsive. They returned my e-mail in a few hours.
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 06-02-2014, 11:27 AM
gasgasman's Avatar
Make sure the flapper is not upside down.
Old 06-02-2014, 04:43 PM
Did as John suggested and sent S3 an email and got a fairly quick response.
The response I got was that GG made the flapper in 3 different sizes! Suggested I remove material from the cylinder or flapper to make it clear!
2011 EC300
Old 06-02-2014, 08:18 PM
twowheels's Avatar
Well then go ahead and fire up your porting tool. If the part isn't right, one would expect the original seller to cover the shipping.
Steven Beane #275
afterhourscycle.com
Loss of power - suspect power valve Jonny Halls Enduro Engine - 2 stroke 4 01-22-2013 09:56 AM
power valve nut bonkeye Enduro Engine - 2 stroke 4 10-11-2012 06:40 PM
power valve sticking? any help? nambo-trev Enduro Engine - 2 stroke 6 03-11-2011 07:45 AM
Power valve malfunction Warwick Simpson Enduro Engine - 2 stroke 2 08-27-2008 07:10 PM
Power valve bens25au Enduro Engine - 2 stroke 2 02-09-2008 11:02 PM
