Old 06-14-2010, 06:30 AM
bmxplus10 bmxplus10 is offline
Default 2003 fse450sm. boging out at partial throttle
okay so i went riding in the north georgia mountains all day, my bike ran as good as she ever has. when we were heading home, we stopped, got some gas and left 10 mins into the ride home my bike started to feel as if it was running outa gas. then i relized it was at a certain rpm ,it i had to ride 60 miles home at about 40mph i draind the gas checked my spark plug fuel injector is working fine.... i dont know these nikes very well just seeing if anyone has had simular problem and could let me know how they fixed it.
Thanks
Old 06-14-2010, 06:33 AM
forgot to add that the bike starts and idles just fine. just bogs out about 1/6 of the way through the rpm range
Old 06-14-2010, 09:01 AM
Nick's Avatar
Nick Nick is offline
I would lean towards water in the fuel as it happened just after you filled up.
Old 06-14-2010, 05:10 PM
i drained the tankand put GOOD gas in it and drand the whole fuel system. it starts fine but still bog out. i forgot to metion on the way home on my 60mile trip it started to run normally for maybe 4-6 mins then it went back to boggin out and only letting me go about 40-45 in 6th gear. sooooo im kinda clueless at this point hope someone has an answer it would be greatly apreciated
Old 06-14-2010, 08:30 PM
HuskyDude's Avatar
HuskyDude HuskyDude is offline
Doubt it will solve anything but you might want to try a fresh plug to eliminate that first. With just happening at a certain throttle I might lean toward a plugged carb.
HuskyDude
10 EC300XC
08 TE510
07 TXT 280
77 TY175
Old 06-14-2010, 09:34 PM
bergerhag's Avatar
My guess is that your TPS sensor is shot, or a short in the wiring for it, that gets shorted by the throttle somehow. Check the wiring first, then get IT hooked up to service pc, with the Technoresearch VDST software.
Old 06-14-2010, 09:48 PM
the TPS was gonna me my next guess ill take it apart tom. and check all the conectioons.
thanks for the tips everyone please keep em coming
Old 06-15-2010, 08:54 AM
Qui-gon's Avatar
Qui-gon Qui-gon is offline
Is the vent hole on the fuel cap plugged or partially blocked? That might produce the symptoms you describe. Tank gets a partial vacuum which drops the fuel pump pressure. try running it until it does it then release the cap.
06 Gas Gas FSE 450 USA
Old 06-15-2010, 01:21 PM
speeddemon speeddemon is offline
I have had a similar problem with a Scorpa T-ride 250f because the CDI unit was broken. The previous owner of this motorcycle modded the CDI so the motorcycle would rev to 12000 rpm instead of 10000 rpm standard. It worked well for 2 months and then it started bogging outafter 2000rpm rendering the motorcycle useless offcourse. After a new CDI unit was installed it ran normal again but just to 10000rpm. Maybe that's the solution to your problem.
Gas Gas Halley 450
KTM 690 Enduro R 2010
Triumph Speed Triple 955i
Old 06-15-2010, 04:09 PM
so i did so readin around on the forums and found out about those 2 relays that go bad . i swtiched em and my bike works fine now so im going to just get 2 fresh ones t be safe but thanks a lot everyone for you input
2003 GG wild 300 throttle cable? firefighterjlklm Other GasGas Bikes/Quads 7 02-04-2011 07:00 PM
Throttle cable 2003 250ec T-roy General Discussions & Announcements 4 04-04-2010 01:39 PM
Thumb throttle Patswild300 Other GasGas Bikes/Quads 4 11-10-2008 03:12 PM
Throttle problems Guido / Denmark Enduro Engine - 2 stroke 1 11-25-2007 10:30 AM
Fuel map on FSE450SM 2006? jan Enduro Engine 4 stroke (including EFI & Exhaust) 1 05-26-2007 04:15 PM
