Old 04-22-2012, 09:09 AM
Silver Silver is offline
Default 2011 brakes
What crosses over from other bikes to my 2011 250. Wire around rear wheel yesterday knocked out cotter pin on brake pin letting pin fall out. Which in turn let pads fall out but not before breaking one in half. 4 sets of used pads from my 07 don't work. Rode for 4 more hrs no rear brake not fun . Brake pin will be saftey wired from now on. First real ride on my 11 with core exp Love it best bike I've riden to date. Exp works awesome. Its like cheating on tight single track.
Old 04-22-2012, 09:42 AM
GasGas's Avatar
GasGas GasGas is offline
08 Yamaha for the rear. Front are still the same Honda pads. You can also replace the pin with the standard threaded type.
2018 EC 300
Old 04-22-2012, 09:43 AM
MJC MJC is offline
Late model yzf pads(07-12) are the crossover for the rear brake pads.
Old 04-22-2012, 09:57 AM
Thanks guys Yamaha dealer just down the road.
Old 04-22-2012, 01:22 PM
Mazikeen Mazikeen is offline
I just installed EBC rear pads number fa367r, I blew my rear pads out in two rides so will try these sintered. EBC stated to not use the factory shims on their pads so I did not, didn't say why, fit perfect, ran it around the yard enough to seat them in, noticeably more "sticky" than the oe, not as progressive a brake feel, however, once stinkin hot, they maintain the sticky but become more progressive? regardless, that is a good part number to cross if needed.
And yes, I keep my eye on the cotter pin on each ride, and have the pin safety wired. I saw this "threaded" stainless pin mentioned here on ebay, for both front and rear, no directions, so I'm guessing you have to tap out the caliper to install. I would likely use this if I were to lose my original, might as well try it if you have to buy one anyway, would still recommend crossdrilling the head and safey wire regardless.
Old 04-22-2012, 02:06 PM
GasGas's Avatar
The stock caliper is already threaded for the regular pin.
2018 EC 300
Old 04-22-2012, 02:30 PM
Binni's Avatar
Binni Binni is offline
What year honda pads for the front? Is it the same pads as cr 250?
Gas Gas EC 300 '07
dare I mention? KTM EXC400
Old 04-22-2012, 07:25 PM
MJC MJC is offline
Yes, 95'-07' I believe.
Brakes & mounts Dennis Enduro Chassis & Body 0 05-22-2011 06:15 AM
Bleedin brakes!!!!!! Pepperami Enduro Chassis & Body 8 01-12-2011 09:55 AM
Brakes redrider7202 Enduro Chassis & Body 5 04-05-2010 05:45 AM
Bleeding Rear Brakes GMP Enduro Chassis & Body 6 11-16-2009 09:00 PM
No Rear Brakes!!!!! matt4wheels Enduro Chassis & Body 5 04-21-2007 02:06 PM
