Old 08-09-2012, 01:05 AM
davedunaway's Avatar
davedunaway davedunaway is offline
Unhappy 06-300 not running
My 300 is sick. It fires up runs for a bit than dies. Pulled the plug and checked for spark - none. Waited five minutes checked again have spark now put plug back in and it starts only to die again in a couple minutes. This same routine went on 3 or4 times. About two weeks ago I tore the little black box off the coil. Parts finder calls it a regulator/ alternator. I kept riding the last two weeks without it even did a race and it ran fine. Could I have fried the coil I assumed the little box was just for lighting. Any ideas?
Dave
Old 08-09-2012, 05:05 AM
Caravan Monster's Avatar
Yes, the little black box is for the lighting output (yellow wire). If you don't need lights, my suggestion would be to make an ignition only loom. Get rid of the handlebar switch and replace it with a simple engine stop switch. Less to go wrong. Study the wiring diagram in the manual and it's fairly easy to work out. Also check under the ignition cover. If there's any sign of dirt in there, you're going to need to pull the flywheel and remove the plate and clean everything. The '06 cases can let in water, and when dirt carried in the water gets onto the crank, it can wear out the main bearing seal, and then the main bearing.
'00 Montesa Cota 315R
'13 Husaberg TE 300
Old 08-09-2012, 11:44 AM
Default 300 sick
Okay, so running without the little black box won't hurt the coil. I don't have a light switch on the bars just a kill switch. I check under my ignition cover quite frequently and it's clean. I'm still thinking coil though, how can I test it?
Dave
Old 08-09-2012, 12:24 PM
have you tryed a new plug, could be buggered
Old 08-09-2012, 08:24 PM
Default Sick300
Have tried three different plugs. Same thing. Now I have no spark at all. Starting to think it could be a broken wire in my harness. I'll strip the tape off and start checking. Just to rule it out is there a way to check the coil?
Dave
Old 08-10-2012, 02:21 AM
I reckon you could check the resistence of the coil, but what reading to look for, I don't know. What is the join between the coil and the HT lead like ? - that can get loose over time. The wiring loom is probably the element most prone to damage and time spent checking through that would be well spent.
'13 Husaberg TE 300
Old 08-10-2012, 02:58 AM
savage sausage's Avatar
savage sausage savage sausage is offline
Make sure you have good earth point(s) also as caravan monster suggests go through the loom.
Buy a new coil & HT lead
It could also be a faulty kill switch
Old 08-10-2012, 11:06 AM
Dave
i dont know how to check a coil to be honest
i think you have got to check the loom over to see if there is a problem and as savage said the earth on the coil. i would clean and WD40 all the connections (connectors) oh savage bought up another good one about the kill switch just disconnect it and check for spark. has it got a ignition barrel.
what i would do is start at one end say the stator plate working up after checking a section try and see if there is any change, sorry i cant be more help
Old 08-10-2012, 09:11 PM
Default 300-happy
I think I have it sorted out. Took apart the HV coil lead , it was loose clipped the ends and installed a fresh cap. Also found a loose connection at the CDI , cleaned up all wires and connections. Bike fired up and I took it for a good blast around the farm, no problems. Tommorow I'll give it a good run on my home track which is some of the most disgusting real estate in the pacific northwest.
Anyway thanks everyone for your help and suggestions .
Dave
Old 08-29-2012, 08:28 AM
Jryd06GG Jryd06GG is offline
I have an 06 300 and very similar problem as well, my remedy was the spark plug boto itself had zero resistance, $ 2.95 later it was fine for three weeks of hard single track. last night it just did on me after 30 seconds of riding...have a weak spark, might throw a new coil in.
06 DE 300
03 CRF230F (girlfriends)
03 MTN CAT 800 144
77 John Deere Liquifire 340
CLAMP IT
2006 ec 300 not running as it should eviljim Enduro Engine - 2 stroke 8 08-06-2012 10:18 AM
running out of fuel? cchracer77 Enduro Intake/Carburetion - 2 stroke 30 03-04-2012 10:20 PM
03 300 not running tophat General Discussions & Announcements 22 08-23-2011 03:51 AM
Running hot Brian VT Enduro Engine - 2 stroke 9 10-01-2008 07:25 AM
Running In Dingo Enduro Engine - 2 stroke 3 07-26-2007 11:36 PM
