Old 05-25-2011, 12:29 AM
Vinny's Avatar
Vinny Vinny is offline
Default Oil change
I was changing my oil. Drained it. Started filling it up and before I arrived to 1100 cc it started pouring out of the top.
I removed the middle drain and removed some oil. Still high. Thought about it.......removed the lower oil drain.......a few cc came out.
. How could this be ?? A clog or something ? Running great ( No overheating) just before starting the oil change.
V.
Vinny
Austin , Tx
A wonderfully working and hard riding '05 GG 450.
Old 05-25-2011, 05:41 AM
bergerhag's Avatar
oil reservoir in frame only holds 1 liter. Here's what I do:
  • drain sump and frame
  • replace filter
  • fill 1 liter in frame
  • put the fill cap back, and start the bike, leav it idle for 30 secs, then turn it off
  • fill the remaining 2 dl
Old 05-25-2011, 06:40 AM
Vinny's Avatar
Does that mean the start want have oil running to the engine ? I'm just nervous to do some damage.
Thanks .
Vinny
Austin , Tx
Old 05-25-2011, 08:27 AM
bergerhag's Avatar
Oil pump for pressure lubrication is fed from frame reservoir. When starting after a filter change engine will run a few seconds while building pressure. This is normal.
Old 05-25-2011, 10:27 AM
BigChina BigChina is offline
Drain the frame??? Can you tell me where the drain for that is??? I have only ever used the drain on the bottom of the engine.
Thanks!
Old 05-25-2011, 02:43 PM
bergerhag's Avatar
Thanks!
Dont worry, dry sump went away with the 2005's. 2006 and up has wet sump=no frame reservoir.
Old 05-25-2011, 05:05 PM
Vinny's Avatar
Thanks. I'm going to work on it now. Who would of thought an oil change would take a day to complete .
Vinny
Austin , Tx
Old 05-25-2011, 09:37 PM
Whew....thanks! can't believe how much i am learning about my bike!
Do I need to change my springs?? hallam76 Enduro Suspension 21 03-23-2011 12:58 PM
caliper change widebear Enduro Chassis & Body 2 01-27-2011 02:23 PM
Jetting Change f14rio Enduro Intake/Carburetion - 2 stroke 12 05-02-2010 08:12 AM
Hmm, should I change to the DE300? BlueLghtning General Discussions & Announcements 10 01-18-2010 09:10 AM
Oil change... FFRDave Enduro Engine - 2 stroke 14 06-29-2007 11:14 PM
