Trouble shifting into 2nd
I am having lots of trouble shifting from 1st to 2nd or from neutral to 2nd. Almost feels like the shift lever is stuck when I try to shift. It is fine shifting throughout the rest of the gear range, and fine when shifting down into 2nd from 3rd. I am using rotella T4 15-40. Could it be a mechanical issue or maybe just oil related. Maybe I can add some ATF to see if it helps?
I would pull the outer clutch side cover off and look at the shift scorpion.
They can develop a sharp edge that would hamper shifting. |
Are you talking about the star shaped part? I have no clue what is meant with "scorpion"... Last edited by Doc Brown; 09-01-2019 at 03:46 AM. |
Yes.
Should be obvious when you look at it while shifting. |
Ok I will check it out. Are you referring to part 22/22A ?
http://partsfinder.onlinemicrofiche....20TRANSMISSION |
Part 22 is the sprocket.
The scorpion is attached to the shift shaft. Will be on the right side, below the clutch basket. |
shifting problem | muellersq | Enduro Engine - 2 stroke | 9 | 05-15-2018 08:21 PM |
Problem shifting into 1st gear. | jgas | Enduro Engine - 2 stroke | 9 | 01-31-2013 03:38 PM |
Shifting issues | koka-nee | Enduro Engine - 2 stroke | 3 | 01-26-2011 09:57 AM |
Shifting Problems | jyellard | Enduro Engine - 2 stroke | 2 | 05-18-2009 05:05 AM |
Not shifting while under load???? | zero_chances | Enduro Engine - 2 stroke | 4 | 02-16-2007 07:40 AM |
