Go Back   Rieju & GasGas Legacy Riders Club Forum > Classified Advertisements > Parts
Parts New/Used Components and All Bike Part Outs
Old 02-23-2017, 04:02 AM
Mick Mick is offline
Default 2011 EC300e part out
Bike has 270 hours on it.
Parts are sold as first come first serve basis.
All prices do not include shipping. Prices not written in stone, hopefully they seem reasonable. May of forgotten a couple things.
I will keep the list up and update it so you guys can see what is left.
My last part out, I under estimated some of the shipping cost, larger items I will take to Fedex to get an exact quote.
Sold AS-IS
SOLD Engine minus e-start assembly, ran great when I parked it, needs counter shaft, may need an over haul.
SOLD E-start assembly, w/wiring harness, switches, gear, covers, etc.
CDI
$100
SOLD Pipe OEM. Dented but repairable
$75
SOLD FMF-Q. Hole wore in side from side panel rubber spacer repaired with aluminum stock/jb weld. Not pretty but it works...repair hidden by side panel.
$75
SOLD Marzocchi 45mm forks (stock)
$385
SOLD Ohlins 888 rear shock (stock)
$225
SOLD Triple Clamps 45mm
SOLD Scott's stabilizer frame bracket bolton for top mount, with Fastway 1 1/8th" topmount barclamp w/hand guard combo.
$175
Front wheel with fresh bearings, typical dings and scratches. Also extra brand new in package All Balls bearing kit.
$175
SOLD Rear wheel with fresh bearings, comes with disc and Supersprox 48 (worn), typical dings and scratches
$175
SOLD Front Axle
Have 2 rear axles
$25 each
SOLD All plastics/headlight
SOLD OEM Radiators, both crashed but repaired by Mylers
SOLD Plastic Frame Guards
$10
Front Brake caliper, master cylinder/lever, hose (no banjo bolt for the master cylinder or bracket for the fork, they were sold)
$130
Rear Brake Caliper & Hose (No pedal or MC)
$80
SOLD Magura Master Cylinder Clutch complete assembly
$165
AJP Clutch Master Cylinder (needs new seals)
$60
OEM Tank with Cap (no Petcock), leaked from cap when new
$50
SOLD Clarke 3.2 Gallon tank
$75
SOLD Carb Keihin 36mm
SOLD Subframe w/battery tray, a bit tweaked but usable
$150
SOLD Frame with street legal title, new kickstand/chain roller tab welded on.
$400
SOLD Swingarm, with TM chain slider
SOLD BRP Chain Guide (rear) worn still has some life in it
SOLD IMS Stainless Foot Pegs
$75
SOLD Airbox
$30
SOLD Full Linkage
$100
SOLD TwinAir Air Filters (2) used
$5 each
SOLD OEM Bar Mounts
$10
Rad/Engine hoses
$10
SOLD Kickstand w/Enduro Engineering wide foot. Front brake bracket
SOLD Seat, small tear at the bottom towards the tank
$50
Picture of bike right before I parked it.
2017 Beta 300RR
Old 02-23-2017, 07:44 AM
pj7's Avatar
pj7 pj7 is offline
Can I get a price on all the plastic, plus the headlight, but not the frame protectors shipped to Georgia 31602?
Old GGs: 01 XC300, 02 XC125, 03 DE300, 03 DEO200, 01 SE300, 2011 EC300
Current: 05 DE250, Showa forked frankenbike 300, 05 DE300, 19 YZ250X
Old 02-23-2017, 08:06 AM
I can do $115 shipped. Shrouds are a little beat up...left side had one of the bolt holes pull through, use a KTM chain slider washer to hold it to the tank.
2017 Beta 300RR
Old 02-23-2017, 09:01 AM
pj7's Avatar
pj7 pj7 is offline
Thanks - sent you a PM
Old 02-23-2017, 12:53 PM
I would like the headlight, if it is not sold.
Old 02-23-2017, 01:47 PM
Sorry already sold, went with all the plastics.
2017 Beta 300RR
Old 02-23-2017, 03:50 PM
frankinberg's Avatar
Is the swing arm in good shape
Old 02-23-2017, 03:56 PM
Not in bad shape, typical scratches, I'll get some pictures of it when I get home from work for you.
2017 Beta 300RR
Old 02-23-2017, 05:32 PM
hamilton's Avatar
hamilton hamilton is offline
I'll take the chain guide. Sent you a PM.
15 GASGAS EC 250
19 Sherco SE 125R
Old 02-23-2017, 07:25 PM
How about swing arm and carb 300.00 plus shipping to 80602 pay with paypal
2011 ec300e carb access bluespark Enduro Intake/Carburetion - 2 stroke 5 06-22-2013 06:18 AM
Problem with Trailtech Vapor on 2011-EC300e erniebearskin Enduro Electrical & Wiring 2 05-20-2012 08:53 AM
2011 EC300E Plastic Preload Ring Moto7man Enduro Suspension 5 11-29-2011 06:06 PM
2011 EC300E maiden voyage Bobt250 General Discussions & Announcements 24 01-06-2011 01:33 PM
