Messico Pipe cracked!
I have a 2003 GasGas 250 with a Messico pipe that only has about 10 hours on it (the pipe), it has never been hit and has always had an eline carbon guard. I noticed this morning when I went to start it that it was blowing some smoke from behind the pipe guard. I rode it and after cleaning it this evening, I removed the guard to find a hairline crack in it about two inches long!
The crack is right where the pipe makes the tight bend off of the manifold. Can these nickel pipes be welded? It looks like it would just need a good bead put down the length t of the crack. Any thoughts? Sure would be nice to pay someone a few bucks to weld it rather than shelling out another 200 plus for a new pipe... Thanks |
Tig or oxy acetalene only. with mig it will crack again
Dont Braze or solder it eaither because it will also crack.
Send it to http://www.piperepair.com/ it will be done right!
I'd oxy/fuel weld it,, but curious why its recommended not to mig? The nickle is just a very thin plate,, and I've mig welded mounts back on in the past and never had issue.. Also Solder is a no but brazing? depending on the crack location I'd recommend against this but when piecing together pipes I dont see issue with brazing..
Where do you live? I live in Port Orchard, WA about a mile from Les Tinius. I can weld it for you, no problem.
Grampy 2003 Gas Gas 250EC 2008 Suzuki C50T "Forever runnin against the wind" |
Brazing will most certainly take the heat,, the coned pipes are tack welded then sealed with brazing.. The 2stroke exhaust does not get hot enough to melt good braze.. solder yes,, it will run like wax.. But I cant remember the temp,, but brazing rod flows at 1200F? Check out custom pipe builders websites and you will see more use braze when testing,,, in production they tig,, just looks better..
Send the pipe to the shop, they will blow out any dents, fix the leak, and decarbonize the pipe. The Messico pipe is not cheap, a bit thin, yes, but a good solid perofrmer!
Alright, it depends on what rod you use for brazing but with the heat and combined stress (rocks, logs, ruts, and so on) will crack brazing.
Best Pipe Messico, FMF or DEP | gasser250sm | Enduro Engine - 2 stroke | 7 | 12-25-2008 06:01 AM |
