Old 07-29-2013, 12:45 PM
TBUBBA TBUBBA is offline
Default 2011 Rear Brake Pedal on a 2012 or 2013
Anyone every tried mounting an '11 or older rear brake pedal on a '12 or '13?
Old 07-29-2013, 04:53 PM
bergerhag's Avatar
Just had a brief look on the 2010 125cc, it migth work, however the distance from the pivot bolt to the pushrod mount is 10mm shorter on the 2010 125 compared to the 2012 300. 50 mm vs 40 mm. I dont know if the older 300 used the same brake pedal as the 125. There is also a bit of pivot bracket offset difference, the 2010 sits deeper.
Old 07-29-2013, 06:23 PM
StuJohnson's Avatar
StuJohnson StuJohnson is offline
I have a 2011 rear brake pedal sitting around somewhere. I will try and find and see if it might work...
2012 - XC 300 Racing
Seattle, WA
Old 08-06-2013, 04:22 PM
Thanks guys. I was just looking for a solution in case the '12 and '13 pedals get out of supply as it looks like the '14 is back to the old style.
Old 08-06-2013, 06:50 PM
rgranger's Avatar
rgranger rgranger is offline
The new pedal goes behind the frame, not sure that the 11 would work as that runs in front - but I haven't been out to look at mine in almost 4 weeks...
Rob Granger / Katy, TX EC300
Breaking more things by 8:00AM than most people break all day.
Old 12-02-2013, 09:27 PM
robszombie's Avatar
robszombie robszombie is offline
Anyone find out anymore on this, or is there a retrofit option available?
The older set up seems better IMO (I'm on my 3rd brake pedal now & it's been damaged already!!!!!!).
Old 12-02-2013, 10:56 PM
wa_ndro wa_ndro is offline
Yep "apparently" the 2014 outside the frame pedal will bolt right up to the 2012/13, just get the return spring and pivot bracket with it.
http://www.gasgasrider.org/forum/showthread.php?t=15950
Rear brake pedal wmcpb04 Enduro Chassis & Body 6 11-24-2012 03:58 AM
2012 EC250 brake pedal robszombie General Discussions & Announcements 18 11-06-2012 09:59 PM
