Old 04-30-2018, 08:45 PM
Jetster220 Jetster220 is offline
What gauge wire did you use to rewire the ground on the starter?
Also, another tip is use a dremel and ruler to grind some chain adjustment notches into the swingarm for easier chain adjustments.
Old 04-30-2018, 09:59 PM
I used 10 guage wire.
I crimped the terminal end on the wire, put some liquid electrical tape on the joint, then heat shrinked the connection.
I cut the front mounting point off on the plastic cover. That way I would get a better grounding point.
A zip tie was used on the front for good measure.
Old 05-01-2018, 06:12 PM
A zip tie was used on the fron for good measure.
I pitched the plastic cover in the bin. It was just a mud catcher.
Also when I got my CDI back from being reprogrammed, the dealer had given me a larger diameter positive battery cable too. I’m not sure if it was the CDI or the new cable that made the huge difference but the bike will cold start in gear now. Starting is flawless.
Old 05-02-2018, 11:35 AM
Originally Posted by memphis2857 View Post
Also when I got my CDI back from being reprogrammed, the dealer had given me a larger diameter positive battery cable too. I?m not sure if it was the CDI or the new cable that made the huge difference but the bike will cold start in gear now. Starting is flawless.
My 2018 had the re-flashed CDI box and larger battery cable when I purchased it a couple of weeks ago. I have not had one issue with starting, cold, hot, in gear, etc. About 8 hours on the bike now.
As someone who had always poked fun at riders who want e-starts on their two-strokes, I am ashamed to admit I have not used the kick start once.
Old 05-16-2018, 06:26 PM
Motocrotts's Avatar
Motocrotts Motocrotts is offline
I replaced the stupid phillips head screws with Allen heads on top of the carburetor. M4 x.7 x 12mm. Picked them up at Ace Hardware for .95 cents each.
Old 06-02-2018, 09:12 PM
This was posted on FaceBook.
Reposted with permission.
My buddy Chris Evans and his recent bad luck with a cracked clutch cover, served me as a good reminder to share this tip with everyone here. Regardless of the year model, check your rear brake pedal to see if you can get a little more clearnace between the pedal tip and case.
Before you start grinding though, start by simply loosening up the 2 allen bolts that attach the tip to the brake lever, push the tip away from the case, then re-tighten the bolts. Then you can see what you need to modify. Depending on year model, this might be the only thing you need to do.
Pedal too close to clutch cover.
In stock form, you can see how the brake pedal tip is cocked sideways. A simple fall over in a rock garden will force the pedal tip into the clutch cover.
Note how I have ground away the sharp edges. Also, I had to grind away the edge of the tip, (see where I am pointing?) This allowed the tip to be bevel with the brake lever when I reassembled. In other words, the tip isn't overhanging the pedal now..
See the difference? Next step is to replace the allen head bolts, with 2 hex head bolts. See how the allens are sticking up, and close to the case? The hex heads will allow a bit more clearance.
Old 06-18-2018, 06:59 PM
Larsa's Avatar
Larsa Larsa is offline
Default The signal horn is to close to front fender
Moving the signal horn
Drill 13mm hole in the horn holder
Cur GasGas GP 300-18, Prev GasGas EC 300 Racing-13, GasGas EC 300-10, GasGas EC 300-07 GasGas EC 300-05, GasGas EC 250-02,Suzuki RM250-98,Suzuki RM250-88, Honda CR250-86, Yamaha YZ400-79, Beta CR125-81, SWM 50-77, Italjet 50-76 www.dufvenberg.com
/Larsa
Old 06-20-2018, 07:21 AM
CDN Rick's Avatar
CDN Rick CDN Rick is offline
They aren't Phillips head... The small dot in the corner of the cross indicates that they are JIS head. Most phillips head drivers will strip them easily. My JIS driver has never once cam'd out on one. I did replace them with Allen Head screws on my last gasser since the PO had ruined them all with a Phillips driver.
2018 GasGas EnduroGP250
2018 GasGas TXT GP300
1994 Honda CR500 (Ice Racer)
Old 07-02-2018, 09:18 PM
I installed the Motion Pro T3 throttle cable on my '18 GG.
It routes in the conventional manner, in front of the bars.
Use part # 10-3000. 100% perfect fit.
Old 07-27-2018, 03:55 PM
This was passed on to me.
Issue: Air filter side cover loose.
Repair. Install new grommets. Shown below.
You will need to remove the OEM grommets and drill the holes out with a 1/2" bit.
Access is still easy, just needs a firm tug.
KTM part # 47106003160
Last edited by gasgasman; 10-07-2018 at 07:28 PM. Reason: Pics keep getting deleted for no reason
P-Tech protection for 2018 Gas Gas Gibnut Enduro Product Announcements 6 10-07-2018 06:23 PM
Tricks for holding down head o-rings? motogroove Enduro Engine - 2 stroke 10 05-14-2011 08:55 AM
Gas Gas 125 Trail Tricks/ RB Designs - Ride Report hasslbri General Discussions & Announcements 5 06-25-2009 11:16 PM
carb tricks again .... skid jackson Enduro Intake/Carburetion - 2 stroke 6 07-25-2008 01:33 AM
Carb tricks skid jackson Enduro Intake/Carburetion - 2 stroke 9 07-05-2007 12:30 PM
