#11
I would like to hear some thoughts on this. I have done this to many bikes successfully.
#12
You know, I really did not want to believe that going up on the pilot at our altitudes would help but it does. I conducted repeated tests with and without RB mods on a 250 and 300 using multiple needles. Surprisingly, on my 250, the best low end was with a 52 pilot (AS1), an N1EE needle, number 8 slide, a Boyesen Rad Valve with carbon reeds, local tuner head mod, and the reed spacer removed. It jumped off the bottom as strong as a 300 and then fell flat on it's face due to the rich taper and could never tune it out. I believe the lesser atmospheric pressure at our altitudes will not "pull" enough fuel at a given RPM through a pilot jet (remember, it is all about orifice size, pressure, atomization, and timing of the atomized fuel getting to the combustion chamber). A larger pilot gives it access to more fuel to offset this weaker vacuum in the carb. The end result is that a larger pilot does work at higher altitudes.
Eric
2018 GG 300 GP 2014 GG 300 Racing E 2002 ATK 605 Dual Sport 2003 KX/KDX 220 hybrid 2021 Kawasaki KRX 1000 Trail Edition 1974-86 Vintage Can Ams, SWMs, Puchs, etc. |
#13
I have no intention of having a carb mod done, but I won't be surprised now if a fat pilot gets me hopping along even faster than before. I'm curious, if several step ups are taken, if I end up back on a W diameter needle to get a better transition coming off of the pilot. I know after going up and down from the 172 main the NEDH and 172 are very happy together so I'd hate to start over on all that. Anyway, didn't mean to hijack, but this definitely provided some interesting insight. Last edited by GGRider01; 06-02-2016 at 10:41 PM. |
#14
Eric
#16
Eric
#17
While the specific jetting suggestions may be close, you need to remember all bikes are slightly different and you need to jet your specific bike for the riding conditions. I am pretty sure your base jetting is different from other bikes so you need to work from your base line.
Assuming similar riding temperature ranges, I have found that dropping the pilot and main jets 1 size worked well for 6 to 9k ft worked well and drop 2 sizes and drop the needle one clip for 9K to 13K+. After you reject you will need to adjust your idle and idle mix as well. Regarding the question on increasing the pilot size. It helps compensate for a weak vacuum signal like many GG engines have with large squish and big 38mm carbs on 200 cc and 250cc engines. If you already have the squish and carb mods done it should work out well as indicated above. You can also help increase the vacuum by adding a little ignition timing. |
#18
40 Pilot
NEDW on the 3rd clip 165 Main Air screw is 2.5 out. 50:1 with Opti2 and 91 Octane. I use this combination riding in the Rockies. Very pleased. |
Once again someone asking for jetting advice | husley | Enduro Intake/Carburetion - 2 stroke | 10 | 01-16-2011 11:29 PM |
06 250 Jetting Advice | Brian | Enduro Intake/Carburetion - 2 stroke | 4 | 08-28-2010 06:57 PM |
Jetting advice | Silver | Enduro Intake/Carburetion - 2 stroke | 11 | 11-02-2009 04:12 PM |
Jetting for Colorado | bondo | Enduro Intake/Carburetion - 2 stroke | 12 | 08-03-2009 12:54 PM |
Colorado Jetting for a 06 300 EC??? 7000 ft - 10,000ft | coloradogasser | Enduro Intake/Carburetion - 2 stroke | 2 | 12-17-2008 11:41 PM |
