Changing fork springs
Can this be done with the front end left on the bike??
IIRC .... I'm thinking the tricky part would be keeping the little rod from sliding down into the fork tube while trying to swap out the springs. If the rod responds to a magnet you could get it back up with a magnet extender but I'm thinking its aluminium.... |
That's how I did mine. I think the rod is steel.
Claude 2019 XC300 2010 Nambotin 300 sold '07 EC300 sold '06 EC300 sold '78 Suzuki RM250C2 '75 Yamaha YZ250B sold |
Put the bike on a stand, unscrew your fork caps, then lift up the front wheel and put another stand under the wheel. This way you can work on the spring change with the fork fully compressed and there will be no need to fish out the inner rod..
sweeet!!
I wouldn't have thought of that!! |
Damn that was easy!!
Thanks for the tip B hag ... spring change out was boob!! any tips for changing out the rear ohlins?? |
To pull the rear shock.
Remove the exhaust pipe and unbolt shock. Pull out on the right side of bike. You will have to move the swing arm up and down as you pull the shock. I saw Billy Burns do this in about 2 min. |
Where to buy fork springs for WP | dank | Enduro Suspension | 4 | 05-07-2010 05:28 PM |
Fork Springs | Looki | General Discussions & Announcements | 4 | 04-10-2010 06:52 AM |
Fork springs - 0.46 | stay_upright | Enduro Suspension | 4 | 03-26-2009 11:16 PM |
Changing fork oil in Zokes? | ktmguy23 | Enduro Suspension | 2 | 03-21-2007 11:53 PM |
