Old 04-22-2014, 08:48 AM
rbm33 rbm33 is offline
Default 48mm Zoke question
Im having a little issue with the forks on my 2011 300. they work pretty good in the sand and the fast stuff with just a couple of clicks out on the comp it works awesome in the rocks, roots and tight stuff. The only problem is that with the softer setting it is really unstable at speed. And with the harder setting it seems like I feel every little rock and root on the trail.
What do you think I should try? I was considering trying the firmer setting and backing off the preload just a half turn or so hopeing to get a setting that works in a little broader range of terrain.
Old 04-22-2014, 03:32 PM
What are you current settings? When were they last serviced?
Old 04-22-2014, 04:23 PM
wence's Avatar
wence wence is offline
Bronze Level Site Supporter
Just a thought but try backing off the PFP a little ...
Xr 250 ( first bike)
98 Rmx
2008 280 Raga replica
2012 Gas gas ec 300 E
Old 04-22-2014, 05:32 PM
I just had them revalved at solid performance. im not sure of the exact settings right now I will have to check but they are just a click or two from being in the middle.
I was kinda thinking that to I will give that a try this weekend.
Old 04-22-2014, 07:44 PM
hamilton's Avatar
hamilton hamilton is offline
Try this, first make sure your rear sag is correct. I like mine at 100mm. Set comp at 15 clicks out (top) rebound 15 clicks out (bottom) set pfp preload all the way out. Find a good test loop same terrain over and over. go four clicks out rebound better or worse? If better go two more and so on. if not go the other direction. Do the same for comp. I found the magic in the rebound setting. When they both work well find some faster whoops and add preload to the pfp 1/4 turn at a time, check o-ring on fork tube you should be using all the travel. Add preload until your using all but the last inch of travel. Only one change at a time. Hope this helps, good luck.
15 GASGAS EC 250
19 Sherco SE 125R
Old 04-22-2014, 08:00 PM
Good info Hamilton. I agree the rebound makes a massive difference in how it handles in the roots. I forgot to set my rebound clickers the other day and they were wide open. Rebounding so fast that they would push back when impacting things. Wound it back to 13 clicks and like magic they began working like they should.
Old 04-22-2014, 08:31 PM
hamilton's Avatar
Yeah, I really like these zokes after getting them set up and knowing what to adjust for certian conditions. I think my settings would work well for trail riders to a class enduro racers.
15 GASGAS EC 250
19 Sherco SE 125R
Old 05-19-2014, 10:41 AM
3beejay3 3beejay3 is offline
Care to elaborate? I really like these forks, but am far from an expert in suspension setup and tuning.
Mine are still stock on my 2012 XC250es. I weigh about 200 fully geared. I'm not sure what my spring rate should be. I'm having trouble in the deep whoops and heavy hits. Love the forks everywhere else; roots, chop, ruts, corners & love the front stability.
I'm also wondering if there is a storehouse/database of info on how to set these up and tune them for varying conditions?
Zoke 48's? wence Enduro Suspension 13 12-05-2011 08:44 AM
45mm Zoke performance toolmaker Enduro Suspension 61 04-05-2011 05:30 PM
Recommendations on a zoke tuner? stvbird Enduro Suspension 2 02-13-2008 06:40 AM
