300 hard starting warm Having some carb issues.
I have a 2011 300 . All electrical is working fine.
I picked this bike up, left it in the basement for 2 months and then went to an enduro. I had a long day. Bike was pig rich. And Very hard to start warm. Like let it sit 10 minutes then start it. 35 f 20 % humidity Got home found 36mm ASII 6.5 Slide NOZH 3rd 40 Pilot 178 main Air screw No effect. FLoat 6.5 I lowered the float to 8mm. It seem to help starting but ran still to rich. No Power. A little bit of change with Air Screw I just installed a # 7 slide that is From My RB modded A.S.I It Runs Much better. Very Crisp. Will need g2 Throttle cam for tight single track. BUT""" Air Screw has no effect. Even with idle screw out. Idles great. If shut it off sometimes it starts good , sometime it takes 20 kicks Todays Weather 55 F 20 % humidity Ed
2011 Sixdays 300 Last edited by Ed Ventura; 03-11-2012 at 08:27 PM. |
They all look farrrking phat for a 36mm carb. Bailey ran the NOZH in his 2010 300 at similar temps and elevations to myself (1000ft+ 90F high RH%) in a 38mm ASII - 42 NOZH#1 165. I remember thinking the main was super lean on his but it made great power from all reports and no mechanical issues. A 36mm will generally require leaner jets as there is a greater vacuum/pull of air and fuel through the carb throat. The NOZ is a 3 taper needle (same tapers as stock N1Ex) with a half clip leaner adjustment). Third taper generally means fat fuelling towards WOT so a smaller main than if you used a single/twin taper. Your bike is currently jetted very close to stock. 42 N1EF#2 175 40 NOZH#3 178 1 size leaner on the pilot, 2 sizes leaner on the needle diameter, half a clip richer on the needle, and a size richer on the main. Last edited by Jakobi; 03-11-2012 at 08:22 PM. Reason: stock jets.. my bad |
Thread Tools | |
Display Modes | |
Extremely hard starting problems | Crankin04 | Enduro Engine 4 stroke (including EFI & Exhaust) | 27 | 01-11-2021 02:12 AM |
Carb issues - Float bowl? | Hicksi | Enduro Intake/Carburetion - 2 stroke | 7 | 10-19-2011 11:21 AM |
04 EC 300 Hard Starting | lordfeyr | Enduro Engine - 2 stroke | 4 | 01-25-2010 01:18 PM |
2004 450 FSE Hot Starting Issues- | MTNBK | Enduro Engine 4 stroke (including EFI & Exhaust) | 2 | 06-30-2009 07:19 AM |
Hard starting - Timing change? | mattmax | Enduro Engine - 2 stroke | 14 | 03-03-2007 01:03 PM |
