Old 04-05-2019, 11:16 PM
Banditpowdercoat Banditpowdercoat is offline
Default 1998 Stator wattage and info
So I have a 98 EC250 and its been stripped of her lights. I want to add some LED headlights In my bike, the stator has 3 wires. What's in this thread. 2 Yelows and a pink. Originally, the bike was wired a yellow to gnd, Pink to Regulator. Wires were melted and shorted. But I measure the windings and get about same Ohm readings between all. I'm assuming its a Open Delta type of configuration or split phase? Pink being center point, Yellow to pink is X volts and other yellow to pink is also X, where yellow to yellow is XX volts?. What I want to know, is what is the wattage of each winding? if anyone knows. So I can closer match my lighting draw and not have the regulator constantly dumping and over working it.
Also, whats the max wattage of the stock regulator? I don't care that it's AC, I will rectify after. I just want a stable 12v
Bike will not be street legal, just want/need great night vision
Old 04-06-2019, 10:36 AM
slocalspode's Avatar
slocalspode slocalspode is offline
Default 98 GG Wiring
I have a .xps document file of the Ducati Style wiring diagram.
I don't think it shows the output, but, it shows how the old system
was wired together.
Ya'want it?
Old 04-06-2019, 10:55 AM
Thx again Jeff. That did help. The stator IS what I thought it was. Wattage now is the TBD part just to be safe. I ended up wiring between the yellows (both windings) as that made the most voltage at idle. But I am leery as to the stock regulator able to dissipate the extra juice. So I'll go back to single winding for my LED's for now until I can verify winding wattage
Old 04-07-2019, 08:38 AM
Zman's Avatar
Zman Zman is offline
As I recall the wattage was 125W or 150W.
2014 XC300 R Stator wattage EC_CC_Rider_300 Enduro Electrical & Wiring 5 12-28-2016 01:20 AM
1998 ec 250 darren8724 "Wanted to Buy" & "Want To Trade" 0 11-02-2015 12:15 PM
DIY rewiring for higher wattage kendunn Enduro Electrical & Wiring 1 01-05-2010 02:28 PM
Hi all, should I 1998 EC 250?? Mudwiz General Discussions & Announcements 1 05-27-2007 11:26 AM
