Old 09-21-2014, 12:52 PM
Kyle01 Kyle01 is offline
Default Idle / Slide lift screw doesn't do jack s*it
09' EC250. Runs fine otherwise. I ended up adjusting the throttle cable for now but it's not right... I ordered a stock plastic replacement screw. The jetting is recorded in the manual (previous owner jetted) and has performed well until yesterday.
Old 09-21-2014, 02:10 PM
Neil E. Neil E. is online now
The plastic screw with it's M5 thread is not a snug fit in the carb. The actual hole is tapered due to the casting process. If the screw comes coated with a white substance, do not remove it. This is some kind of thread filler that helps to made the screw fit properly.
If it comes as bare plastic, you might want to wrap it with teflon tape to try and make it fit better.
Old 09-22-2014, 09:23 AM
The one I've got coming has the thread sealer on the screw so I should be good to go. If that doesn't keep me idling I should be looking at my pilot correct?
Old 09-22-2014, 09:52 AM
It's actually the combination of pilot jet and needle shank diameter that governs your idle/off idle quality.
Old 09-24-2014, 12:09 AM
This is what's in the carb currently-
38 pilot
#7 slide
N1EG 2nd clip
175 main
1.5 turns out
The new idle screw isn't in yet but damn, this thing won't idle unless I adjust the cable out. When I do that I can get it to idle down crazy low- seems like the pilot is right (although compared to most of you at sea level I'm a little lean)
I've got a 42 pilot. Is it worth trying?
Old 09-24-2014, 02:07 AM
kyton's Avatar
kyton kyton is offline
I got the same issue.
my setup @ sealevel
42 pilot
#6 slide
N1EC 2nd clip
175 main
1.5 turns out
What did you adjust on top of carb or at the throttle? I adjusted mine at the top of the carb.
Old 09-24-2014, 03:50 AM
The N1Ex needles have extremely short straight sections, which means it doesn't take many turns on the idle adjuster screw to lift the slide up to the point that you're actually trying to idle on the needle taper.
Back the idle screw right down on a hot engine, set the AS at 1.5 turns, and change pilots until you get one that idles. OR change to a needle with a longer straight section and do the same, but will be much easier.
Old 09-24-2014, 08:57 AM
Awesome advice- thanks. Can you suggest a needle that's easy to get? I've had great luck with the JD needles on other (4t) bikes- but they don't seem all that popular. I read a lot about CCK/CCM needles, there is so much info that it's overwhelming a little. I just want a good solid middle of the road needle.
Old 09-24-2014, 07:56 PM
my setup @ sealevel
42 pilot
#6 slide
N1EC 2nd clip
175 main
1.5 turns out
I adjusted it at the throttle as I was in some nasty muddy woods and having to kick it back to life would have been a chore.
Old 09-25-2014, 12:23 PM
swehollow swehollow is offline
I have something similar on my gasgas and i need some advice.
1. It will idle if i screw the idle screw almost ALL the way in and i dont hit the gas.
2. The airscrew does not seem to have much effect at all.
3. When i hit the gas it revs up but takes far to long to come back down, and once it does it often cannot sustain idle anymore.
What should i do?
Got my needle (n1ec)on third notch, A 040 and a 168 at this moment. slider number 6.
would love any tips as im traveling past my gasgas shop in the morning.
idle screw position antsx Enduro Intake/Carburetion - 2 stroke 1 10-23-2012 10:06 PM
New idle screw bkrjohn Enduro Intake/Carburetion - 2 stroke 1 07-29-2012 03:00 PM
Extended idle or fuel screw super_rat Enduro Intake/Carburetion - 2 stroke 7 01-01-2009 09:02 PM
Idle adjustment doesn't work JCW Enduro Intake/Carburetion - 2 stroke 12 07-24-2008 07:59 PM
Supermotard 250 idle screw effect JonnySM250 Enduro Intake/Carburetion - 2 stroke 2 09-10-2007 12:23 PM
