Old 10-15-2010, 05:52 AM
bergerhag's Avatar
Default Is the flywheel nut a left hand thread on my 300?
manuals are somewhat unclear. Can someone confirm this before I start applying some real force?
//thx
Old 10-15-2010, 07:47 AM
Zeal Zeal is offline
No, it should be a right hand thread if you are talking about the nut that holds on the magnets of the stator.
The nut that holds on the clutch basket is a Left hand thread.
At least that's the way it is on 06-10
Old 10-15-2010, 09:20 AM
GMP's Avatar
GMP GMP is offline
Not on any GG I have worked on from '00 to '07. All mainshaft threads are right hand (conventional). Flywheel is also right hand. The crank pinion nut is a left hand thread.
Old 10-15-2010, 10:38 AM
iancp5's Avatar
iancp5 iancp5 is offline
What's a crank pinion?
Old 10-15-2010, 11:35 AM
GMP's Avatar
GMP GMP is offline
Pinion GEAR, on end of crank that drives the clutch, water pump and PV.
Left hand rear brake??? getndirty Enduro Chassis & Body 71 12-29-2014 02:56 PM
Experience bleeding left hand rear brake? roostafish Enduro Chassis & Body 17 01-06-2010 01:45 PM
Flywheel removal....Thread size. wence Enduro Engine - 2 stroke 4 12-12-2009 04:19 PM
Hand Guards dozerash General Discussions & Announcements 6 05-10-2008 08:53 AM
Sand under left hand PV cover!!! highspeedsteel Enduro Engine - 2 stroke 11 08-22-2007 02:36 PM
