Old 12-26-2007, 01:56 PM
Motarded1 Motarded1 is offline
Default Speedo Sensor and mounting
Can someone post up the speedo sensor and where/how it mounts? My bike is missing one and want to make sure the part is correct.
Old 12-26-2007, 02:36 PM
eff's Avatar
eff eff is offline
You can see mine here
Old 12-27-2007, 09:20 PM
Thanks! It is electrical correct? What is it reading on the wheel/rotor?
I also assume the bracket is holding it in place?
Old 12-28-2007, 07:17 AM
eff's Avatar
eff eff is offline
Yes.
I;m not sure what you are asking, but if you mean the wheel diameter that varies with every tire.
No, the bracket I think you are referring to is just a guard. The sensor threads right into the caliper mount.
Old 12-28-2007, 09:42 AM
I mean since its not mechanical then it must use a magnet and pickup. Wondered where the magnet is on the rotor or wheel.
Old 12-28-2007, 10:21 AM
eff's Avatar
eff eff is offline
Look at the lower left hand side of the hub and you can see the magnet between the hub and disk.
Old 12-28-2007, 10:35 AM
The plastic part there with the 2 metal pieces on it?
Old 12-28-2007, 10:42 AM
eff's Avatar
eff eff is offline
It's aluminum with a round magnet on it.
I circled it here:
Old 12-28-2007, 10:59 AM
I wondered what that was, so how is that mounted to the wheel or is it to the rotor?
Old 12-28-2007, 11:04 AM
eff's Avatar
eff eff is offline
It's mounted to the hub, with a small screw.
BTW, what year bike are you trying to mount this on?
oil sensor 450fse 03 jjbaker1 Enduro Engine 4 stroke (including EFI & Exhaust) 1 03-12-2009 05:54 AM
Odo sensor on B/O TooBadBrad General Discussions & Announcements 2 06-21-2007 07:23 PM
