2007 EC250 Crank Bearing?
Hi Guys,
I just found out that my 2007 EC250 Left side (ignition) crank bearing is bad. It sounded a little loose since the bike was brand new, and it finally worked the crank seal out of its bore. Thats a first for me! Anyway, after pulling the stator plate off, I found the crank bearing to be loose but not yet a catastrophic failure. I remember a few years back there was a rash of bearing failures, does anyone remember what the fix was? And, does anyone know what part # I should give to my local bearing house to get my replacement part? Thanks, I'll let you know how it all turns out... P.S. should I replace the other side bearing while I'm there? FYB |
Ignition side crank bearing failure? | wence | Enduro Engine - 2 stroke | 37 | 06-16-2016 07:21 PM |
07 Crank bearing... NEED URGENT HELP. | wence | Enduro Engine - 2 stroke | 11 | 05-23-2010 02:25 PM |
03 EC300 crank bearing problem | bwalker98 | Enduro Engine - 2 stroke | 4 | 05-04-2010 05:05 PM |
