Old 06-19-2016, 03:19 PM
Yngvim Yngvim is offline
We're you able to set the TPS in ECU before you made the changes or after?
+170mV means less air less fuel and I think it will affect the timing as well
EC 250 2001, Fse 450 2004
Old 06-20-2016, 12:26 AM
Tafka Tafka is offline
I made changes to CO-trim before and after i made changes to TPS.
When i had +290mV then i tried changing the CO-trim from +10 to +30 (Originally i had +22). I rode some time with +17 trim and had no problems (maybe only that engine got little bit too hot sometimes).
At the moment i have +170mV(+20 trim) and it rode very good, it had more torque (i got the front wheel off the ground much easily than before). But still the issue that it started to stall little bit too easily and very quick snap on the throttle sometimes stalls it too...higer idle should fix that in my opinion. I set the CO trim to +25 now and hope to test it out tomorrow.
But yeah i should say that +170mV gives more torque but with +290mV engine revd little bit quicker?(at least when listening with ear).
So i'm confused at the moment...i like the low end torque but if that(+170mV) gives too lean mixture then thats not so good either.
I checked the TPS with guzzydiag, and didn't see any dead spots (turned the throttle really slow and watched the TPS angle and voltage).
What else should i check? Replace injector?
Old 06-20-2016, 02:36 AM
I'm not shoure if it is running lean , wrong timing can cause the engine to run to hot, but you can try any voltage between 170mV and 290mV and find the sweet spot. The lower value is 4.5° opening on the throttle. It doesn't hurt to use injector cleaner.
Hope you will finde the setting you like
Old 06-20-2016, 04:10 AM
Just to be sure...every time when i adjust TPS, I should reset TPS also?!
Will try to play with the CO trim few days.
Still it's very strange that this stalling started in the middle of the ride....
Old 06-20-2016, 04:22 AM
It should be set at 290mV. All the parameters in the ecu are written according to that. It seems like TPS reset didn't work when you adjusted the throttle body first time and you are compensating for that by changing the TPS value. It should be set at 290mV after that you can make adjustments without TPS reset
Old 06-20-2016, 04:43 AM
Hmm...okay. Will try that. At the moment i have always made TPS reset.
Old 06-20-2016, 06:57 AM
I have not been able to use guzzidiag to set the TPS.
Maybe we're doing it wrong.
Here is a link to some help
http://wildguzzi.com/forum/index.php?topic=69168.0
Old 06-20-2016, 07:26 AM
When i have played with TPS then GuzziDiag shows XX.XX value for TPS angle...when i reset it then it resets it to 6.37 degrees. So i assume that resets the TPS correctly....
Old 06-27-2016, 06:12 AM
I'm really tired of the problems...took the throttle body off and cleaned it and the injector. Put it back together...adjusted the TPS to +290mV, reset TPS....and it's horrible now. Even when cold it starts to stall and when hot then it doesn't want to idle at all...
I will leave it for a couple of days, because i might screw something up even more when frustrated.
Ordered new injector, coolant sensor and TPS....if changing those doesn't help i'm out of ideas
Old 07-01-2016, 02:17 PM
Leeky Leeky is offline
Hi gents, sorry to hear some of you are struggling still with your bikes, I hope my post has been a little helpful - if not just use it as a work flow to check off the things that could have an affect.
I've since found mine to be absolutely amazing, after routing out the bad wiring (left as a present by a previous owner) it's dependable and reliable. I changed the regulator and battery recently as I did a quick check on the battery voltage when running and found it to be 18v, I took the opportunity to fit a Yuasa battery and she usually starts first hit on the button now - hot or cold.
I've been racing recently on a 2 stroke KTM, the gasser a bit heavy but great for green lanes with the old man - I might just end up keeping it
2004 450 FSE starting issues rodneymj Enduro Engine 4 stroke (including EFI & Exhaust) 5 11-17-2014 02:08 PM
Gas Gas 450 FSE 2003-4 starting Issues stainless601 Enduro Engine 4 stroke (including EFI & Exhaust) 0 05-04-2013 11:42 AM
300 hard starting warm Having some carb issues. Ed Ventura Enduro Intake/Carburetion - 2 stroke 1 03-11-2012 08:12 PM
Hot starting. nick790 Enduro Intake/Carburetion - 2 stroke 0 04-21-2010 02:44 PM
2004 450 FSE Hot Starting Issues- MTNBK Enduro Engine 4 stroke (including EFI & Exhaust) 2 06-30-2009 07:19 AM
