Enduro Engine 4 stroke (including EFI & Exhaust) 4 stroke engine, EFI, and exhaust discussion |
#11
Sounds like harmonics caused the bolts to back off and then once loose they have almost no shear strength so they got sheared off. If you can keep the replacement bolts tight I bet they will hold up.
#12
I was also looking for a flywheel puller for my 2004 FSE 450. It has a Ducati flywheel and the outside of the threads on the flywheel mic out at 30 mm.
So, can I assume that I need a 30 mm puller? Also, since most suppliers list the pullers by motorcycle brand can I get any advice on what Japanese or Euro brand uses the 30 x1.5 mm puller Tony |
#13
Just a short update on pullers. I did find..... http://www.mbsmfg.com/bymounco.html
online and they list pullers by Motorcycle brand and by size. The 30mm1.5 RH I orderded was $21 delivered and they had it in stock Tony |
2002 ec400fse starter clutch | jason r | Enduro Engine 4 stroke (including EFI & Exhaust) | 6 | 09-09-2009 04:47 PM |
gear problem | new gas gas | Enduro Engine - 2 stroke | 2 | 01-06-2009 09:53 AM |
EC 125 Gear Shifter Problem | jonnyweston | Enduro Engine - 2 stroke | 6 | 09-17-2007 11:41 AM |
ec125 2002 changing gear problem ? | fastfilli | Enduro Engine - 2 stroke | 8 | 05-20-2007 09:13 AM |
Gear box problem 07 ec300 | peterr | Enduro Engine - 2 stroke | 5 | 02-26-2007 01:07 AM |
