Old 07-24-2018, 11:05 AM
Default KYB swap which triple clamp?
Just took delivery of some 2010 yz250 KYB SSS. Measuring them compared to my gasgas,
Ec300
Top 54mm
Bottom 57mm
KYB SSS
Top 56mm
Bottom 59mm
So which triple clamps are people using for these? Looks to me like they each need 2mm from top and bottom... I know the yz clamps can fit with new bearings, but what gasgas triples are best?
2016 RM-Z450
Old 07-24-2018, 01:18 PM
Danj56's Avatar
Danj56 Danj56 is offline
Bronze Level Site Supporter
I had my GG clamps machined, that way I can use the stock fender, headlight mounts and steering stop.
Old 07-24-2018, 02:00 PM
The YZ ones look a little mass produced but work well with blocks for stops welded to them. I painted black. Front guard I just redrilled. Headlight, well it just straps on on my 7.
Old 07-24-2018, 05:08 PM
I've ordered 2009 which are a little prettier. Do you know what size/part number bearings to order?
2016 RM-Z450
Old 07-24-2018, 05:06 PM
So you had 2mm machine from each? Aren't they a bit thin?
2016 RM-Z450
Old 07-25-2018, 05:48 AM
Danj56's Avatar
So far after a couple years I've had no problems, Have another set of GG clamps and a set of Yamaha clamps if I do.
Old 07-25-2018, 02:07 PM
Ahh, yz top had a smaller od so I used that. Heck i had a thread but search on my tablet hasn't found it, have a look and it should cover it and what I fit for spacers and stops etc
Old 07-25-2018, 04:34 PM
I've had a look on all 16 threads you've started and nothing there, will search deeper!
Edit - found, you openly admitted to hijacking the thread! http://www.gasgasrider.org/forum/sho...earings&page=7
2016 RM-Z450
Old 07-26-2018, 02:14 PM
Elvis74 Elvis74 is offline
I use the original gasgas tripple clamps. I machined the clamping diameter and it works fine since about 200 hours. I am doing not only woods ridding, I am also on the motocross track with my gasser
Gesendet von iPhone mit Tapatalk
Old 07-27-2018, 02:21 PM
Too late .
2010 forks fit 2009 yokes anyway. I read somewhere that they'd changed the upper diameter on the forks but haven't found the problem..
2016 RM-Z450
Scotts Triple Clamp Part # 6043-12 & steering stabilizer handlebar clamp jeffp Parts 0 12-31-2015 07:07 PM
triple clamp mike989 Parts 0 06-02-2015 12:04 PM
Which yamaha triple clamps for KYB swap roverhybrids Enduro Suspension 14 07-27-2013 12:48 PM
Triple clamp ?? rippn450 Enduro Suspension 22 04-18-2011 09:21 PM
Can I swap Triple clamps and front forks? FFRDave Enduro Chassis & Body 2 05-24-2010 02:32 PM
