S3 cylinder/power valve help?
Trying to put the power valve assembly into a new S3 cylinder...I cannot seem to get it right!
After many, many, many attempts I keep ending up with the index for the triangle piece on the wrong side of where it needs to be. The assembly will only rotate a small amount. Remembering taking it out, the whole assembly being able to spin 360 degrees, so I put everything into the old cylinder and everything seems fine on the first try. Is it possible something is not right with this cylinder or am I totally overlooking something simple?
2011 EC300 2013 TXT300 Factory Replica 2014 Polaris Assault 2004 Snowhawk 600H.O. |
After taking a few minutes off and returning to it, I have realized that the flapper can not fully recess in the open position. S3 didn't machine enough material out!
If i were to take a Dremel and try to get a little clearance do I risk damaging the cylinder coating? Really don't think I should have to but at this point seems like the only thing to do!
Correct me if I am wrong, but the stop points would be controlled by the bolt head stopping the movement at fully open and closed?
The material needed to be removed would be a very small amount on the uncoated side of the cylinder. Returning the cylinder would be costly ($150-$200) with two way international shipping!
Shoot S-3 an e-mail. I did a few months back,very responsive. They returned my e-mail in a few hours.
'12 XC 200 TTX Sold '15 XC 250E Sale pending |
Make sure the flapper is not upside down.
Loss of power - suspect power valve | Jonny Halls | Enduro Engine - 2 stroke | 4 | 01-22-2013 09:56 AM |
power valve nut | bonkeye | Enduro Engine - 2 stroke | 4 | 10-11-2012 06:40 PM |
power valve sticking? any help? | nambo-trev | Enduro Engine - 2 stroke | 6 | 03-11-2011 07:45 AM |
Power valve malfunction | Warwick Simpson | Enduro Engine - 2 stroke | 2 | 08-27-2008 07:10 PM |
Power valve | bens25au | Enduro Engine - 2 stroke | 2 | 02-09-2008 11:02 PM |
