Old 12-28-2014, 11:19 AM
Default How is my piston?
Need to make sure it has at least a 175 main and a 40 pilot then go from there. Also if it has these jets currently make sure they are clean. That plug tells the story of a bike that is way too lean on the main
Old 12-28-2014, 11:29 AM
GLantern's Avatar
GLantern GLantern is offline
K I'll check the jets before any changes are made. I'm thinking I'll richen it up then check everything. Then I'll follow up with a change in the mixture.
Old 12-28-2014, 01:52 PM
Yes very good plan. 50:1 is what the manufacturer recommends and I would think they know best. I don't believe your problem is your fuel mixture I just think it's not getting enough. One other thing to look at is make sure the carb is seated properly and there is no chance of an air leak anywhere
Sent from my iPad using Tapatalk
Old 12-28-2014, 02:57 PM
GLantern's Avatar
Thanks Memphis, and thank you everyone else for the advice here. I'll keep following up as I get into the jetting.
Old 12-28-2014, 06:09 PM
Check the flywheel side main seal as well. My 2013 model was showing signs of passing oil at 65hrs, which means a good chance it was able to suck some air too. Higher rpm is where it'll lean out if its going to. My bike showed no signs of 'running lean'.
Old 12-30-2014, 04:05 PM
I agree! Or even better, just change the seal! They are 10 a penny!
2016 RM-Z450
Old 12-30-2014, 05:00 PM
Rick's Avatar
Rick Rick is offline
Not directly related but food for thought!
It's a good read and worth the time so your not chasing your tail!
http://www.chronicmx.com/dirt-bike-t...stroke-spooge/
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
Old 12-31-2014, 02:48 AM
its definitely worth saying that the internet can't jet your bike for you, BUT!
When ever I have found my jetting to be different from the average (normally richer on 2 strokes) there has been another contributing factor causing this discrepancy. It is definitely worth ensuring you have the baseline jetting everyone with the same year model has and go from there. Ignore my jetting below as it is for a 2006 with different carb and head mod!
Good luck! Once all the demons left by previous owners were sorted, by bike has been my favourite off roader so far! I can't see my self ever selling it even if I get a new one!
2016 RM-Z450
How does this piston look? jan_b Enduro Engine - 2 stroke 9 11-25-2013 01:12 AM
new piston Madhead Enduro Engine - 2 stroke 8 01-04-2013 07:24 AM
B or C piston coachtech Enduro Engine - 2 stroke 11 02-14-2012 08:29 PM
New piston? Biff Enduro Engine - 2 stroke 2 03-23-2011 08:09 PM
how does my piston look? rupecopp Enduro Engine - 2 stroke 16 06-09-2008 08:09 PM
