Old 11-19-2013, 12:06 AM
Coby_p Coby_p is offline
Default 2011 ec200 marzocchis
My throttle side fork slides over the axel even if its tightened down all the way. i have tried a new axle, no change. So in the meantime I have been using alumn. tape around the axel to shim it, but thats clearly a temporary fix. Anyone have any ideas? Should i contact marzocchi and try to get a new fork bottom? should i find a machine shop that can put a permanent shim on the axel? or should i look for a used set of forks due to the unknown horrors my forks may have in store? I also have no idea how it happened, only noticed it after i brought the bike home
Old 11-19-2013, 06:21 AM
john r b's Avatar
john r b john r b is offline
45's or 48's ?? Race or sixday's model?
Old 11-19-2013, 09:13 AM
Leo's Avatar
Leo Leo is offline
I think you should contact Marzocchi. That's not common.
www.endurohp.eng.br
Sherco ST300 2015 (Trials)
https://www.instagram.com/leocm74/
Brasil!
Old 11-19-2013, 10:33 AM
andoman's Avatar
andoman andoman is offline
When you say "tightened all the way down," are you saying that the gap at the front of the "fist" is completely closed when you tighten up the bolts, thus preventing ANY further tightening?
If not, then it could be that the bolts are too long therefore binding on the bolt's shoulder before the gap is closed enough for the fist to bite on the axle.
Newest Spanish Girlfriend: 2011 300 Six Days
My Daughter is a U.S. Marine
Old 11-19-2013, 03:21 PM
This
Take some pics.
Old 11-19-2013, 06:31 PM
Its the six days model. The gap is closed all the way. i was going to try to shave some metal in between the gap but thats probably a terrible idea. The weirdest part to me is that its only that side. the rotor side has the correct gap, so that rules out the possibility of previous owner forgetting to tighten the axle down and it spinning inside the clamp and loosening it up. Maybe the previous owner didn't know what he was doing and used a torch to heat it up the clamp to get the axle out?
Old 11-19-2013, 06:48 PM
How much play are we talking here?
Old 11-19-2013, 07:38 PM
We're talking sliding the axle in and out of the clamp with the gap fully closed. i have already tried a brand new axle from gas gas and same deal. without putting the front wheel on i put the new axle in the clamp without loosening the pinch bolts. if i push the axle through the throttle side clamp with no gap there is not a single point where the axle will stop sliding. i forgot to mention there are no stress fractures or breaks whatsoever in the clamp.
Old 11-19-2013, 07:58 PM
gasgasman's Avatar
At some point, the pinch bolts were over tightened.
You can take a hack saw and "widen" the gap just enough to get a good purchase.
Old 11-19-2013, 09:18 PM
Stoby's Avatar
Stoby Stoby is offline
Bronze Level Site Supporter
Default wrong axle?
Is it somehow possible you got an older wheel with smaller axle?
I cant imagine any way that you could max out the pinch with the correct axle
2011 ec200 six days Coby_p Enduro Intake/Carburetion - 2 stroke 10 10-29-2014 01:48 PM
Wanted : 45mm Marzocchis richardexclaim "Wanted to Buy" & "Want To Trade" 13 03-13-2013 09:16 AM
Marzocchis on GG300 EC 2011 Mr B Enduro Suspension 2 02-07-2012 10:02 AM
