#11
Armor all as mentioned above is good. But, one of it's components Silicone is the thing.
Been using Silicone spray for years. Use it to keep my chains lubed and clean and always use it to remove and install tires. If I do run into a problem tire which hardly ever happens to me any more I just let out some of the air, lay the wheel out flat with the unseated section facing up, respray that section and it'll pop as soon as you apply additional pressure. Most times my tires pop at about 20-30 lbs pressure. About over inflating to make them pop, I'm not sure how that effects the overall integrity of the tire. I don't worry about it on my small bikes, but I'd never do it on my sport bike with VR tires. I've read articles that have said under-inflate or over-inflate your tire and it never forgets. Tony |
#12
Agree with Coop. Talc on tube (or in tire), windex on bead (spray some then run it around with your fingers). Never fails.
2011 EC300 Six Days 2010 EC300 Nambotin Replica |
#13
Thanks guys, I got the job done with wd-40 and 50lbs from the floor pump.
#14
This is my preferred method too, sometimes two beers are required..........
2011 GG EC 300E, 1994 CR 250R, 1984 RM 250 E, 2022 Ranger 300 "If you stop eating donuts you will live 3 years longer. It's just 3 more years that you want a donut." ―Comedian Lewis Black "I think best when I have a wrench in my hands." Soichiro Honda "Dreams are messages from the deep." -Unknown Sardaukar |
Anyone use a bead buddy?? | nambo-trev | General Discussions & Announcements | 12 | 05-21-2013 08:04 PM |
did u rim bead lock question | jhendr3702 | Enduro Chassis & Body | 2 | 03-08-2010 09:12 AM |
