replacing the lower shock bush/bearing
Hello.
ive got a 2007 model ec 250 ohlins shock, got new kit for the lower mount, can I do it without removing the linkage? If so any tips on how to make it easier? I guess use a vice with sockets? Cheers in advance |
Best to remove the shock completely from the bike.
'12 XC 200 TTX Sold '15 XC 250E Sale pending |
Yep thats no prob, but ok to still do it with linkage all in?
pretty sure you will need to remove the linkage,while your there why not check the seals and bearings? Grease em up if need be.
You can do the bearing with the shock on the bike.
Just remove one of the dog bone bolts and rotate dog bone out of the way. |
Is it then just a case of use vice and sockets to press the old out and new in? ill probably pull the shock and send for a service while a few bits are apart
Tricky part with this method is lifting the bike onto your vise to press the bearing out ;-)
2012 Ohlins lower shock bushing and Problem with shock. | CDBiker220 | Enduro Suspension | 1 | 08-04-2014 09:35 PM |
washers on lower rear shock? | lineman12345678 | Enduro Suspension | 19 | 06-20-2014 04:35 PM |
Stripped lower shock mount | andykr87 | Enduro Suspension | 12 | 05-08-2013 09:11 PM |
lower shock bearing cross-ref? | fasternat | Enduro Suspension | 1 | 02-21-2007 10:20 AM |
