Old 09-24-2008, 09:30 AM
2 strokes 4 life's Avatar
Default FMF Gnarly
Anyone run a LTR jetting kit and a FMF Gnarly on their bike? I have a 2002 EC250. I was woundering if you might know what size pilot, and main i should run. I have a 45, and 185 in right now in the 3rd needle position.
THANKS!!!
2012 Ktm 300xc
2001 Gasgas EC300
Old 09-24-2008, 11:25 AM
PEB PEB is offline
I have never changed jets with a new pipe. Did you get the old Gnarly or the new sst/doma Gnarly? I run a 42/178 in the 2nd slot in my 02 300 if that helps. Lots of jetting info in the database.
Old 09-24-2008, 11:59 AM
SpeedyManiac's Avatar
45 pilot and 185 main sounds extremely rich unless it's winter riding at sea level. Around the trail area I'm usually around 40-42 pilot, 170, 172 or 175 main depending on where I'm riding (river valleys, 175; high alpine I run a 170).
How does your bike run? What's the plug look like?
Old 09-24-2008, 04:49 PM
What does the LTR come with stock? I was running the LTR stock in the middle needle position. When running the LTR set-up i was a little lean on top. It was rich on the bottom thoe. Might have to pull out and check the jets.
The plug was really white brown almost white at the tip. The bike felt fine befor i tore it down but mabe a little lean on top.
2012 Ktm 300xc
2001 Gasgas EC300
Old 09-25-2008, 05:14 PM
What's your elevation? I didn't think PG was that low. For fall riding I'll probably go with a 175 main and probably a 42 pilot, needle in the 3rd clip.
Old 09-25-2008, 07:25 PM
PG is about 1800-2400 at most. Right now its about 3 to 13 degres or so. I am going to take it apart to night and see what is in it. Going to clean it and put all the other stuff together as well. Thanks for the Help.
2012 Ktm 300xc
2001 Gasgas EC300
Old 09-25-2008, 09:27 PM
If the bike is running clean (no blubbering and pulls clean right up to WFO) I wouldn't mess with the jetting. But I'm guessing it's going to be rich. There is a jetting database on here, might be worth a look.
Old 09-26-2008, 08:54 AM
Mounted up the pipe (some bending and what not) and looked at the jetting. It has right now a 185, 45 and #3 postion. Just befor i rebuilt it i had a 182 in it with a 42. So i will ride today or tommorow and see if and where it is rich. I asume be rich then lean on a new top end. I still have a bunch of different jets. Thanks again.
2012 Ktm 300xc
2001 Gasgas EC300
Old 09-26-2008, 12:27 PM
Loosenut's Avatar
Loosenut Loosenut is offline
185 main should be pretty rich. My 300s won't pull onto the pipe clean higher than a 178 main. I hate a blubbery bike.
Mike Baxter
2005 GasGas EC300 (Ohlins front and rear)
2007 Yamaha FZ1
2003 Pampera 280(hers)
Old 09-26-2008, 04:58 PM
Well tommorow i will test and see. I too think a 185 is too rich. I am going to try a playing with them. I have a 185 to 175 anyways.
2012 Ktm 300xc
2001 Gasgas EC300
FMF Pipe, Gnarly? eff Enduro Engine - 2 stroke 11 11-16-2014 01:13 AM
FMF Gnarly gasIdaho Enduro Engine - 2 stroke 19 05-16-2009 01:09 AM
EC300 07/08 FMF Gnarly gasIdaho Enduro Engine - 2 stroke 16 05-08-2009 06:26 PM
Gnarly on a 200 iancp5 Enduro Engine - 2 stroke 4 04-30-2009 07:33 AM
