Old 09-22-2018, 06:15 PM
Gasgas239 Gasgas239 is offline
Default Oil drain bolts?
Hey guys, I just picked up a used '03 ec250 I love the bike I was checking things out an noticed there were 3 bolts on the bottom of the cases I'm assuming one is the oil drain bolt but what are the other 2?
Thanks
Old 09-22-2018, 09:34 PM
cbutler's Avatar
cbutler cbutler is offline
The one in the back right side is the oil drain.The front right is the crank drain.The front left was added by a previous owner and is for assembling the motor at the factory, some people put a bolt in it because it is in the magneto cavity.
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 09-23-2018, 07:56 AM
Oh gotcha, wonder why they wld put a crank drain bolt in?
Old 09-23-2018, 09:57 AM
cbutler's Avatar
From the factory there's just a whole. Some people like to put a bolt in there to keep water from coming in.
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 09-23-2018, 05:41 PM
I've always wondered why other manufacturers haven't!!!
Bloody useful when you accidentally fill the crank cases up with water. Much easier to drop a bolt out of the case than to turn the bike upside down and pump it out the spark plug hole.
Old 10-03-2018, 08:51 AM
I drained the oil to change it an the drain bolt didnt have a crush washer or any kind of oring is this normal for gas gas or the previous owner just leave if off?
Old 10-03-2018, 09:05 AM
cbutler's Avatar
03 should have a O-ring
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 10-03-2018, 09:27 AM
Is that something I can order?
Old 10-03-2018, 12:33 PM
cbutler's Avatar
Yes but you could just go down to the headwear store and get some. I don't think they are hi temp
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 10-03-2018, 05:58 PM
Ok thanks for the info
Coolant doesn?t drain from drain bolt? 2012 250 ec Si176 Enduro Other... 4 11-19-2017 11:03 PM
Best Way to Drain Out Gas VTMTcowboy Enduro Engine - 2 stroke 4 05-10-2016 02:05 PM
Bolts iamovru General Discussions & Announcements 7 08-12-2014 10:58 PM
Drain and Fill Dude Enduro Engine - 2 stroke 1 04-24-2011 06:21 PM
