Old 05-06-2016, 02:39 AM
poelinca's Avatar
poelinca poelinca is offline
You guys are right, just ordered a dial bore gauge and a micrometer just to be sure.
'14 EC300
Old 05-06-2016, 05:40 AM
barossi73's Avatar
Mine was A spec,replaced with an A wossner at 70hrs (200)from new.no problem.you say you have 100hrs on it.is that from new?or has it had a topend previously?if from new the same spec will be fine.
2013 ec200r
Old 05-06-2016, 05:55 AM
poelinca's Avatar
Mine came with B spec from the factory, 100 hours from new (this is the first top-end job for me and for the bike). I'll check before ordering the piston, just to be sure.
'14 EC300
Old 05-17-2016, 05:05 AM
poelinca's Avatar
Measured the cylinder bore last night:
- 0.008-0.009mm is the tightest spot i could find (the needle on the bore gauge changes direction right under the 0.01mm mark, very hard to approximate how much) in diagonal
- 0.02mm exhaust to intake (largest spot i could find)
- 0.01mm side to side
So in the end, same piston will go in. I will also rinse the coolant system with vinegar, new gaskets, clean the PV mechanism and remove any play. Hopefully it will all be good, will keep you informed with the process as I go along and the outcome (ride report) probably Sunday if all goes well and parts arrive soon enough.
'14 EC300
Old 05-17-2016, 06:04 AM
barossi73's Avatar
Get engine extra clean.Leave the 't' coolant fitting on the head if possible.the gasket wont be in the set.remove exhaust spigot.be careful not to bend pv actuator rod.dont let the actuator plate turn clockwise when refitting the nut.you will find you cant remove/refit cylinder 'square'.tip cyl backwards slightly as it comes off the studs and on reassembly lead slightly with rear studs.any writing on rings goes up.ring gaps/locator pins in piston to the rear.check small end bearing is exact match to old.take extra care fitting retaining clips on gudgeon pin,its easy to slip and scratch piston.carefully start rings into bore as you lower cylinder.a little 2stroke oil on the piston skirts.be patient,dont force the issue and it will be all good
Pv gaskets can often be reused if they came off clean.then you have new spares
2013 ec200r
Old 05-17-2016, 09:00 AM
adriano.ro adriano.ro is offline
I use a little oil for new gaskets,in future will be more easily to take off.
Old 06-08-2016, 01:42 PM
poelinca's Avatar
Found:
- oily white slime on the carb slide (witch would indicate water i presume)
- carb mouth where the air boot fits had a "leak", you could see where the dirt came in with water
- small pieces of dirt on the air screw
- no water in the bowl tough
- small pieces of dirt on the boot mouth
All of the above coupled with worn out piston and rings could have caused it right ?
'14 EC300
Thread Tools
Display Modes
2013 started smoking bulbs... rgranger Enduro Electrical & Wiring 16 04-10-2013 08:08 AM
yard sale! smoking cheap prices! jt633 Parts 7 04-04-2013 08:22 AM
07' 300 overheating...I think(4 stroking, and coolant on engine)? CDBiker220 Enduro Engine - 2 stroke 14 11-22-2010 10:22 AM
Ec 250 Overheating New Piston? Elliker Enduro Engine - 2 stroke 6 07-16-2009 04:55 PM
