Old 07-22-2016, 05:39 AM
dewenduro's Avatar
dewenduro dewenduro is offline
Default Sachs shim 7ID & 9ID, where I can buy?
I'd like revalve my 48 sachs fork.
Can anyone tell me where I can buy 7mm & 9mm ID valving shims?
(small piece(44), shipping to Europe/Hungary)
SDI(suspensiondirect),Racingsuspensionproducts: only 9ID
MXTech,RaceTech: I can't see
Thanks
Old 07-22-2016, 12:30 PM
A while back I saw you could get them from the Beta site, the alternative is to grind out a smaller size with a dremmel
Old 07-22-2016, 01:02 PM
husley's Avatar
husley husley is offline
Bronze Level Site Supporter
Are these the 10' red Sachs Forks and are you in the U.S. ?
2015 KTM 450 XCW
2014 350 XCF Wife's
2009 200 ec. Loving it
2007 Beta Rev 3 270
2007 KTM 200 XC Wife's
Public Lands belong to the Public
Old 07-22-2016, 06:43 PM
dewenduro's Avatar
No.
It's a 2009 sachs fork (not racing version) See pictures.
I'm in Europe. (Hungary)
https://goo.gl/photos/97AFLkumSXBd1ywr6
Old 07-22-2016, 06:48 PM
dewenduro's Avatar
Thanks! Wich Beta site?
Dremmel is not a good idea. See this post:
http://www.gasgasrider.org/forum/sho...hlight=dremmel
Old 07-23-2016, 02:32 PM
i saw it on the beta usa site, but cant see them any more. did a bit more research ad it appears that they no longer list them, possibly i believe because the newer sachs forks on the betas are more similar to WP forks now
Old 07-24-2016, 01:31 AM
twowheels's Avatar
The Sachs forks on the Betas continue to use 7mm ID shims.
Beta does not stock the 7mm shims, but we have built some for our own use. The plan had been to have them for large term sale but the process is such that it hasn't made sense to do so.
Steven Beane #275
afterhourscycle.com
Old 07-24-2016, 07:20 AM
Anders Anders is offline
Thanks
You could ask your "local" RG3 suspension shop. I know the one in Sweden works on Sachs and surely have these shims available. However, I don't know if they are willing to sell you just the shims.
You could also contact Michigan Engineering as they offer 7mm id shims on their website. I have just googled it, I have never been in contact with them.
http://www.mei-inc.com/machine/shim/id_7_mm.htm
Sent fra min GT-I9295 via Tapatalk
Old 07-24-2016, 02:36 PM
dewenduro's Avatar
Thank you Guys!
twowheels's Avatar
Michigan Engineering will make you 7mm ID shims if you commit to a minimum order of 1000 pieces ... of any particular size
Steven Beane #275
afterhourscycle.com
Marzocchi 48 shim stack profile. Barbs Enduro Suspension 17 02-29-2016 07:12 AM
Marzocchi 45 shim advice? motopsycho87 Enduro Suspension 17 10-20-2014 12:47 PM
Countershaft sprocket shim 3hunerd Enduro Engine - 2 stroke 5 03-24-2012 09:29 AM
45mm zoke shim id Ed Ventura Enduro Suspension 1 09-22-2008 05:34 AM
Rebound shim recommendations (stiffer) stay_upright Enduro Suspension 4 09-20-2008 02:20 PM
