Old 07-11-2018, 06:40 PM
pigpen966 pigpen966 is offline
Default flasher relay
Hey All, just hooked up some LED turn signals on my GP. They are lighting up slightly. It has the EC harness I'm guessing because all the hook-ups were there. I looked at the wiring diagram and figured out which wire was left and right. Are the stock flashers LED? Do I need to put a LED flasher relay in?
If anybody could help a brother out it'd be much appreciated.
Dick Carnes
"If ya run, you'll only die tired"
2019 EC 300
2018 GP 300
2013 XC 300 (sold)
2006 DE 300 (buddy has it)
Old 07-11-2018, 10:36 PM
kiwigasgas kiwigasgas is offline
Generally LED indicators need a solid state type relay, one that dosnt go click click. They are super cheap now, can get one for a few bucks, should sort out your issues
Old 07-12-2018, 05:22 AM
Except gassers now have the flasher relay as part of the left hand switch block...
You?ll need to fit some of the led resistors to each side of the blinkers instead. Not the way I like to do it but I had to do the same when I fit up the Click n Ride indicators to mine.
Leonelli AC flasher unit jakekamo Enduro Electrical & Wiring 1 04-10-2017 10:36 AM
flasher relay EC 2011 vgstef Enduro Electrical & Wiring 4 04-12-2012 06:51 PM
Indicator relay Hicksi Enduro Electrical & Wiring 5 08-22-2011 09:52 AM
2011 flasher Boom Boom Enduro Electrical & Wiring 8 03-15-2011 09:51 AM
fuel relay Devondan Enduro Engine 4 stroke (including EFI & Exhaust) 4 10-21-2009 04:12 PM
