2018 XC 250 Base Gasket
Anyone know stock base gasket thickness for the 2018 XC 250? I will find out in another 30 hours or so when I do a top end. I just do not want to pull the jug until it is time for that job...
Woundering the same.
And what piston height is recomended, cant find any info about that . |
Eyeball it..
If its the metal coated one (black on each side) they are usually 0.5mm Green is 0.3mm. From memory.. My old 2010 had 1.3mm of gaskets packed between the cases and jugs stock! |
All the 2018?s I?ve seen/heard of 250/300 have had 0.5mm like Jake said.
Back on a gassy! 2018 EC300! 🤘 Txt 280 07 to make me feel like a gumby again |
Thank you kindly gents!
wet base gasket | thejackrabbit | Enduro Engine - 2 stroke | 6 | 02-09-2014 01:03 PM |
Base Gasket re-use? | motogroove | Enduro Engine - 2 stroke | 5 | 06-26-2011 07:56 PM |
!!! Help with Base gasket thickness !!! | timlh | Enduro Engine - 2 stroke | 1 | 05-14-2009 07:58 PM |
Base gasket | Ud_luz | Enduro Engine - 2 stroke | 21 | 05-09-2008 07:38 AM |
Base Gasket | gtsnowcrack | Enduro Engine - 2 stroke | 6 | 09-09-2006 05:43 AM |
