Old 04-26-2010, 08:37 PM
gasser's Avatar
gasser gasser is offline
Originally Posted by fabulous furry View Post
.the plug is stinky black even with the 162 jet ??
i use 1.5 % maxim castor 927 and tried Klotz and motul esther with no change.my SWM 240tf1 ran better in the days.!
Stainlesscycle is right you are way too lean on the main and too rich on the pilot. 1.5% is 67/1 on your oil ratio. Going that lean on your oil ratio will cause your fuel ratio to be rich will cause wet fouling of the plug unless you rejet your carb leaner to work with that mixture. Start with picking a good oil and using that oil at the ratio the oil is designed for. 927 is a fabulous oil mixed at 33/1 (3%) and Klotz will probably work well up to 40/1 (2.5%) but I would never go leaner on the oil ratio than 40/1 with any oil that wasn't 100% synthetic and never leaner than 50/1 (2%) unless the oil manufacturer recommended it for the higher ratios. Jetting should be easiest for you if you use a 100% synthetic oil and mix it 50/1. The reason is GasGas obliviously jetted the carb for that ratio since it is what they recommend. You might want to go 1-2 sizes smaller on the main (than stock) because of the hot weather but drop it only one size at a time and test till you get it right. As for the pilot you may want to start 2 sizes smaller than stock if you ride tight single track.
One last thing to leave you with - it is improper jetting that causes plug fouling not too much oil. I ran 20/1 (5%) in Bultacos for years without fouling plugs.
Old 04-28-2010, 07:00 PM
fabulous furry fabulous furry is offline
thanks for that i will go back to the drawing board..
300 racing 2009
300 Factory replica 2014
250 XC 2018
SWM 250 TF1 1981
TXT 250 2003
Old 05-04-2010, 08:37 AM
dank's Avatar
dank dank is offline
anybody ever heard of a br8evx plug? i dug one out of my ec250 last night and i havnt ever seen one before. ran fine for as long as ive had the bike, but last night it finally gave in and died. so i replaced it with a br8es, but i was wondering if anybody had ever heard of that particular plug and how it compares to say a br8eix, or a br8es?
03 ec250
hyde skidplate, cycra handguads, protaper contours
"what? it seemed like a good idea at the time!"
Old 05-04-2010, 02:53 PM
Rick's Avatar
Rick Rick is offline
http://www.dirtrider.net/forums3/sho...d.php?t=114702
There you go....
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
Old 05-06-2010, 11:27 PM
moto9's Avatar
moto9 moto9 is offline
I read an article in a MX mag that stated " running more oil in the gas actually leans out the air/fuel mixture.
So, for instance mixing 40 to 1 is leaner than if you mixed 50 to 1
I always thought the other way around
Who knew?
I run a BR8EIX
Old 05-06-2010, 11:49 PM
noobi's Avatar
noobi noobi is offline
Yes, because the fuel/air ratio refers to petrol not oil. So more oil means less fuel per same volume, therefore a leaner mixture
fouled plugs, what to do. dank Enduro Intake/Carburetion - 2 stroke 7 05-26-2010 09:15 AM
i keep fouling spark plugs??? tom-s Enduro Engine - 2 stroke 7 08-28-2009 01:37 AM
Oil drain plugs that work! GGLoops Enduro Product Reviews 6 03-03-2009 04:22 PM
Plugs steve Enduro Engine - 2 stroke 2 05-22-2008 06:26 AM
Fouling plugs rupecopp Enduro Intake/Carburetion - 2 stroke 3 08-11-2007 03:43 PM
