Old 01-12-2016, 11:18 AM
Originally Posted by Zman View Post
Here is a list of seals minus the water pump. I believe the seals are the same from year to year but you should double check to make sure these look correct in size for your engine.
1 x LHS CRANK SEAL KOK 20x35x6 ? VITON ktm 47030076100 04-14 105 85 65
1 x RHS CRANK SEAL KOK 38x52x7 - VITON ktm 0760385273 94-14 250 300
1 x COUNTERSHAFT SEAL 30x40x7 Suzuki 09283-30061
Shift Shaft Seal 12x22x7
KICKSTART shaft SEAL 20X30X7
From the parts fiche it looks like there are two seals on the counter shaft, one covering the bearing, and another that is accessible from outside the case.
Old 01-12-2016, 10:30 PM
There is a outer seal around the bushing and one or two O-rings behind/inside the bushing.
Old 02-07-2016, 10:28 PM
Got the bottom end buttoned up today. Transmission gears from the 2004 bottom end looked flawless and mated up perfectly. Glad I did not drop the extra coin for a few new parts, as I have a spare crank and cases for both bikes now. New piston went in as well. Motor will go back into the bike next weekend. Thank you for all the help. Bob from NTMS did a great job setting me up with bearings, gaskets, and seals. I did and will try to support the dealer network as GasGas gets back onto it's feet in the coming months.
Old 02-07-2016, 10:33 PM
Oh, I forgot to purchase/replace the kick shaft seal. Can this be removed/installed without removing the inner cover again?
Old 02-07-2016, 10:44 PM
Originally Posted by GGRider01 View Post
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I've bought two of these. Complete set, everything you need. Not the toughest gaskets, so be careful. Use a very small amount of RTV to keep them stuck in place for assembly. As far as seals go, I would get measurements and start looking for alternative sources.
Sage advice on the RTV. It was necessary, as each of the two dowels were in opposite sides of the cases, which makes keeping the gasket in place a little tricky. I kept the RTV near the motor mounts and away from where the cases need to seal.
Old 04-17-2016, 06:34 PM
Batman Bailey's Avatar
Batman Bailey Batman Bailey is offline
Default gears
I had a gear break a tooth and lock up trans. I had to replace three gears.
Old 04-17-2016, 11:43 PM
GGRider01 GGRider01 is offline
A bit belated, but the common method seems to be to run a course thread screw into the seal, not very deep, and pull out with pliers. Then use an appropriately sized socket to hammer a new one in.
1998 EC 250 Clutch Basket Failure Dukester Enduro Engine - 2 stroke 5 12-10-2014 08:55 AM
CDI Box Failure Mode blitz11 Enduro Electrical & Wiring 7 10-30-2013 03:27 PM
Kick Idler Gear Failure Jason S. Enduro Engine - 2 stroke 3 08-08-2011 04:19 PM
return of the son of the BMW fork failure? motogroove All Other Bikes... 1 06-29-2011 08:40 PM
Hmmmm Ring failure noobi Enduro Engine - 2 stroke 6 04-24-2010 12:22 AM
